Einleitung
In this iFixit manual, we explain the steps involved in replacing the rear right trunk light housing of a 1999 Toyota Camry LE. The major steps include removing the trunk interior, disconnecting the electrical connection, removing the light fixture, replacing the light fixture, reconnecting the electrical connection, and reassembling the trunk interior.
Before beginning this repair, turn off the car, engage the parking brake, and disconnect the battery.
Was du brauchst
Place a 6.35mm or smaller flat-head screwdriver between the black clips and the trunk cover.
Pull down on the handle of the screwdriver until the clip comes out of the cover.
Press the small button on the end of the electrical connector and pull it away from the main electrical connection of the car.
Carefully pull the light housing out of the trunk.
Insert the new light into the fitting of the light housing.
Insert the white end of the electrical source wire into the connector attached to the light fixture.
Align the holes on the fabric with the holes on the interior of the car trunk.
Push the pins into place.
When you have completed the steps you can test the light fixture by starting the car.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
