Zum Hauptinhalt wechseln
2000-2006 Chevrolet Suburban Hydroboost Cylinder Replacement
Was du brauchst
  1. 2000-2006 Chevrolet Suburban Hydroboost Cylinder Replacement, Hydroboost Cylinder: Schritt 1, Bild 1 von 1
    • Open the hood, locate the brake fluid reservoir. Right under that is the Hydroboost device.
    Frag FixBot
    Kommentar hinzufügen
  2. 2000-2006 Chevrolet Suburban Hydroboost Cylinder Replacement: Schritt 2, Bild 1 von 1
    • Use a box wrench or crescent wrench to take the two nuts off that connect the Hydroboost (against the firewall) to the brake system.
    Frag FixBot
  3. 2000-2006 Chevrolet Suburban Hydroboost Cylinder Replacement: Schritt 3, Bild 1 von 1
    • Use a pair of pliers or clamps to pull one of the power steering tubes off. It may leak, but keep a rag nearby.
    Frag FixBot
  4. 2000-2006 Chevrolet Suburban Hydroboost Cylinder Replacement: Schritt 4, Bild 1 von 1
    • Use a crescent wrench to take off the output line of the power steering. There is a O ring inside, be careful not to get debris inside.
    Frag FixBot
  5. 2000-2006 Chevrolet Suburban Hydroboost Cylinder Replacement: Schritt 5, Bild 1 von 1
    • Use a 5/8” wrench to pull last feeder tube for power steering. Again be cautious of dirt and debris.
    Frag FixBot
  6. 2000-2006 Chevrolet Suburban Hydroboost Cylinder Replacement: Schritt 6, Bild 1 von 1
    • Everything should be free, so pull brake system away. Be careful not to put pressure on brake lines as they can break. Keep debris away from this too.
    Frag FixBot
  7. 2000-2006 Chevrolet Suburban Hydroboost Cylinder Replacement: Schritt 7, Bild 1 von 2 2000-2006 Chevrolet Suburban Hydroboost Cylinder Replacement: Schritt 7, Bild 2 von 2
    • Inside there are four bolts. They are tight fits, but use a deep socket to take them off.
    • The white plastic sensor that connects to your brake pedal slides off after pulling the metal tab on the pedal. Use an O ring pick for best results
    Frag FixBot
  8. 2000-2006 Chevrolet Suburban Hydroboost Cylinder Replacement: Schritt 8, Bild 1 von 1
    • Once everything inside and out is free, pull the Hydroboost out revealing the hole in the firewall.
    Frag FixBot
  9. 2000-2006 Chevrolet Suburban Hydroboost Cylinder Replacement: Schritt 9, Bild 1 von 1
    • Left is old, right is new. It might be good to clean both up. It may be required to transfer bolts between the two.
    • Regarding the Hydroboost and Brake bolts, there are reverse threads. So lefty tighty, righty loosey.
    Frag FixBot
    • From now on, you will want to reverse steps 1-9. This is a direct replacement, so no variables exist.
    Frag FixBot
  10. 2000-2006 Chevrolet Suburban Hydroboost Cylinder Replacement: Schritt 11, Bild 1 von 1
    • Replace hoses if needed, but odds are they can attach on tightly.
    • Make sure the brake sensor is on straight, and it is advised to put it together as one, not as two.
    Frag FixBot
  11. 2000-2006 Chevrolet Suburban Hydroboost Cylinder Replacement: Schritt 12, Bild 1 von 1
    • Once Hydroboost is in securely, attach Mounting plate between Hydroboost and Brake System. Tighten, and double check hoses.
    Frag FixBot
  12. 2000-2006 Chevrolet Suburban Hydroboost Cylinder Replacement: Schritt 13, Bild 1 von 1
    • It may be required to attach trim pieces inside of taken off for access. Very simple, two 7/16 bolts.
    Frag FixBot
Abschluss
One of the critical things is to make sure the linkage to the brake pedal to the Hydroboost and the sensor are lined up correctly.
Eine weitere Person hat diese Anleitung absolviert.
Michael
217 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 15
Letzte 30 Tage: 86
Insgesamt: 4,658
