Einleitung
If you can hear a knocking noise coming from the suspension of your car or your car feels unstable during turns, it may be time to replace your car's sway bar links. Fortunately, replacing sway bar links is not a difficult task. Simply follow these instructions, and your car will be stable again.
Werkzeuge
Ersatzteile
Tools needed:
A 14mm socket wrench
A 4mm Allen wrench
Penetrating lubricant
A lug wrench
Torque wrench
Two new sway bar links
To access the bolts first remove cap center from wheel by prying with a screwdriver.
Using the lug wrench, turn the lug nuts for the front passenger side wheel counterclockwise until you break their resistance.
You will need to begin by jacking up the front of your car. If you need help with using a hydraulic jack, see the guide below:
Take the 14mm lug wrench and loosen all the bolts until they come off of the wheel and remove the wheel.
The sway bar link is located behind the brake shield, connecting the sway bar and suspension.
Use the penetrating lubricant to spray on the top nut, which attaches the sway bar link to the suspension.
Use the penetrating lubricant to spray the bottom nut, which attaches the sway bar link to the sway bar.
After taking all the nuts off, use the bar from the hydraulic jack to push down the sway bar so that it is easier to take the sway bar link off.
To put the new sway bar link in, use the bar from the hydraulic jack to push down the sway bar, and then insert the new sway bar link.
Use the 4mm Allen wrench or 14mm socket wrench to tighten the nut onto the bottom sway bar link.
Repeat for the top sway bar link.
Place the hydraulic jack back under the car and lift it off the cinder blocks or jack stands.
Remove the cinder blocks or jack stands and lower the car back to the ground.
Further tighten the lug nuts using the torque wrench.
Sway Bar Links tend to wear out at a similar rates. Repeat Steps 2-13 for the driver's side Sway Bar Link.
8 weitere Nutzer haben diese Anleitung absolviert.
Ein Kommentar
This is slightly wrong. You most likely will need a spanner and an allen key wrench to hold the bolt still while undoing the nut.
