Einleitung
If the radio in your first generation Mini Cooper (R50/52/53) has stopped working or you want to put in an aftermarket radio, this guide will show you how to remove the factory radio. There are no special skills required to do so. Some of the plastic dash panels may be older and more brittle, so be careful when pulling them. NOTE: If you’re putting in an aftermarket radio and want to retain the steering wheel controls, you need to make sure you buy an adapter kit.
Was du brauchst
Grab the knee bolster panel under the steering column with both hands.
Pull it down and out.
Using a Torx screwdriver with T30 tip, remove the two M5 x 2.5 x 25 screws in the left pillar.
Open the glovebox.
Using a Torx screwdriver with a T20 tip, remove the two M5 x 2.5 x 30 screws in the right hand side pillar.
With the glovebox still open, grab the bottom of the passenger dash panel and pull it forward. The panel does not need to be removed, just popped out.
Grab under the driver side dash panel near the radio and pull it forward. Again, the panel does not need to be removed, just popped out.
Pull each side of the middle dash panel until it pops out, like the previous ones.
Grab the left hand side pillar, then pull it out and to the left.
Grab the right hand side pillar, then pull it out and to the right.
The four screws holding the radio in should now be exposed.
Using a screwdriver with a T20 bit, take out the four M3 x 2 x 20 screws holding the radio in place.
For the main connector, pinch the lever arm with the piece of plastic next to it.
Lift up on the arm and pull the connector out.
The radio can now be removed from the car.
10 weitere Personen haben diese Anleitung absolviert.
3 Kommentare zur Anleitung
If your ever in the junkyard and one has an aftermarket stereo but you have no torx or hex, rip off the door sil chrome trim and wedge it in the left and right side of the stereo in the teeny tiny gap from the stereo to metal sleeve to release metal clips connecting the sleeve to the stereo and PUSH stereo inside so you have access to stereo sleeve, put a screwdriver in a hole of the sleeve that fits and pry until it breaks the plastic, it will destroy the metal sleeve beyond bending back but they are extremely cheap and then you can take out the stereo and clip harness with as much wire left as possible, had to do this today and scored a bluetooth kenwood excelon deck for 10 bucks on half off day, gonns make a bluetooth boombox with infinity reference 6x9s also from junkyard lol
