Zum Hauptinhalt wechseln
2001-2005 Honda Civic Tail Light Replacement
Was du brauchst
  1. 2001-2005 Honda Civic Tail Light Replacement, Tail Light: Schritt 1, Bild 1 von 1
    • To remove the risk of electrocution, turn off the vehicle before attempting replacement
  2. 2001-2005 Honda Civic Tail Light Replacement: Schritt 2, Bild 1 von 1
    • Release the trunk latch.
    • The release can often be found on the floor, near the fuel access and hood release buttons.
  3. 2001-2005 Honda Civic Tail Light Replacement: Schritt 3, Bild 1 von 1
    • Remove bulb from tail light assembly.
  4. 2001-2005 Honda Civic Tail Light Replacement: Schritt 4, Bild 1 von 1
    • Remove the bulb from its' socket.
    • Be sure to only remove the bulb. Removing the socket as well will require another replacement in order to properly function.
Abschluss
To re-install a tail light, follow these steps in reverse.
2 weitere Personen haben diese Anleitung absolviert.
Tyler Smith
846 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 4-5, Vijaybhaskar Fall 2013 Mitglied von UMass Dartmouth, Team 4-5, Vijaybhaskar Fall 2013
UMASSD-VIJAYBHASKAR-F13S4G5
3 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
I have an issue with the bulb being stuck in the socket. I can access the whole assembly fine, but for whatever reason the bulb won't come out.
Kyle - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 14
Letzte 30 Tage: 41
Insgesamt: 8,430
