Einleitung
If the rear window of your 2001 Chevrolet Suburban won’t stay open, the struts (also known as lift supports or lift support struts) that hold it up need to be replaced. This guide will walk you through replacing these struts. It’s important to replace failing struts because an unsupported window has the potential to dangerously drop on your head or shatter against any cargo sticking out.
Special Considerations
You’ll want to consider the following:
- Having a partner is immensely helpful. Having someone hold the window open is easier (and safer) than propping it open.
- Some users may need a step stool. Due to the height of the upper strut joints, some users may find it more comfortable to use a step stool or step ladder.
Hazards
This procedure isn’t dangerous, but be aware of the following hazards:
- The window could fall and hurt you. Be sure it’s secure.
- The tabs on the struts could be flung into your eyes. The risk of this is low unless you try to completely remove the tabs or use excessive force when loosening them.
- The grease on the strut joints and mounting studs is toxic. Wash your hands when you’re done.
Was du brauchst
Open the window.
Support the window with either a partner's hands or a sturdy prop.
Position the small screwdriver on the indentation in the lower joint of the strut.
Gently wedge the screwdriver under the metal locking tab and pop it out.
Position the screwdriver on the indentation in the upper joint.
Stand at the back of the vehicle (behind the rear bumper) and face the lower joint of the strut.
Grab the lower joint.
Pull firmly, straight towards you and slightly upwards until the joint pops off.
Stand at the side of the vehicle and face the upper joint of the strut.
Grab the upper joint.
Pull firmly, straight towards you until the joint pops off. Do not pull upwards or downwards.
Remove the new strut from its packaging.
Align the socket of the upper joint with the mounting stud.
Firmly press the joint until it snaps on.
Align the socket of the bottom joint with the mounting stud.
Repeat this process for the other strut. That’s it!
