Zum Hauptinhalt wechseln
2001 Volkswagen Passat Key Fob Battery Replacement
Was du brauchst
  1. 2001 Volkswagen Passat Key Fob Battery Replacement, Key Fob Battery: Schritt 1, Bild 1 von 2 2001 Volkswagen Passat Key Fob Battery Replacement, Key Fob Battery: Schritt 1, Bild 2 von 2
    • Press the release button on the key fob so that key is extended.
    • Locate the small indentation in the middle of the key fob.
  2. 2001 Volkswagen Passat Key Fob Battery Replacement: Schritt 2, Bild 1 von 3 2001 Volkswagen Passat Key Fob Battery Replacement: Schritt 2, Bild 2 von 3 2001 Volkswagen Passat Key Fob Battery Replacement: Schritt 2, Bild 3 von 3
    • Place a plastic pry tool in the indentation of the key fob.
    • Apply pressure and rotate the pry tool until key fob begins to separate.
    • Using light force, pull the key fob apart.
    • Remove the cover on lower part of the key fob and locate the battery.
  3. 2001 Volkswagen Passat Key Fob Battery Replacement: Schritt 3, Bild 1 von 3 2001 Volkswagen Passat Key Fob Battery Replacement: Schritt 3, Bild 2 von 3 2001 Volkswagen Passat Key Fob Battery Replacement: Schritt 3, Bild 3 von 3
    • Use a spudger to remove the battery.
    • Place a new battery in the key fob and press down gently to secure it in place.
  4. 2001 Volkswagen Passat Key Fob Battery Replacement: Schritt 4, Bild 1 von 2 2001 Volkswagen Passat Key Fob Battery Replacement: Schritt 4, Bild 2 von 2
    • Pick up the pieces of the key fob and begin to slide the pieces together.
    • This needs to be done slowly to not break the plastic on the fob.
  5. 2001 Volkswagen Passat Key Fob Battery Replacement: Schritt 5, Bild 1 von 1
    • Press the key release button to make sure that the key fob operates correctly.
    • Press the lock, unlock and trunk buttons and check for the red indicator light to make sure the key fob working properly.
    • Depending on your vehicle, you may need to reprogram your key fob to your car. Either consult a dealership or review your owner's manual on how to reprogram your key fob.
Ziellinie
5 weitere Personen haben diese Anleitung absolviert.
Michigan Tech, Team 4-14, Lauer Spring 2016 Mitglied von Michigan Tech, Team 4-14, Lauer Spring 2016
MTU-LAUER-S16S4G14
1 Mitglied
1 Anleitung geschrieben
2 Kommentare zur Anleitung
verry useful!!
eugen - Antwort Teilen
My neighbor's key broke off the end for her 2001 Passat. She knowing that I am quite handy, asked me if I would try repairing it. I fixed it twice before. Now, instead of simply applying JB Weld again to the minimal surfaces and temporarily fixing it again, I want to disassemble it and repair the key with silver solder. I need a diagram of taking it apart so I can reassemble it so it functions like a new fold-up key fob should. This is such a handy thing, I just need to a diagram. C'mon, VW? Be a sport?
ironchip - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 27
Letzte 30 Tage: 143
Insgesamt: 21,473
