Zum Hauptinhalt wechseln
Einleitung
The thermostat and gasket will set you back about $10 from any auto parts store. The entire process should take less than 30 minutes. Good luck.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
  1. ***MAKE SURE ENGINE IS COLD***                                 Locate the upper radiator hose and follow it to the location where the hose connects to the engine block. The hose clamps to a metal housing called the "water inlet." Loosen the band clamp that secures the hose to the water inlet with a screwdriver. Pull the hose off the inlet.
    • ***MAKE SURE ENGINE IS COLD*** Locate the upper radiator hose and follow it to the location where the hose connects to the engine block. The hose clamps to a metal housing called the "water inlet." Loosen the band clamp that secures the hose to the water inlet with a screwdriver. Pull the hose off the inlet.
  2. Locate the two bolts that secure the inlet to the engine block and remove them. Use a 12 mm socket and ratchet. Pull the water inlet off the engine block. Due to age, the inlet may stick to the block. Place pressure on the side of the inlet to break the seal, if needed.
    • Locate the two bolts that secure the inlet to the engine block and remove them. Use a 12 mm socket and ratchet. Pull the water inlet off the engine block. Due to age, the inlet may stick to the block. Place pressure on the side of the inlet to break the seal, if needed.
  3. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
    • Scrape the base of the engine and the bottom of the inlet to remove the old gasket material and to clean the mating surfaces.
  4. Pull the old thermostat out of the engine and place the new one into the engine. One end of the thermostat has a large spring. The spring sits inside of the engine.
    • Pull the old thermostat out of the engine and place the new one into the engine. One end of the thermostat has a large spring. The spring sits inside of the engine.
    • Place a bead of RTV gasket maker around the bottom edge of the water inlet. Place the water inlet over the thermostat and bolt it into place. Using RTV gasket maker instead of a gasket compensates for pitting that occurs in cast iron. It helps to promote a better seal between the engine and the inlet.
    • Slide the radiator hose onto the inlet and secure it with the band clamp.
Abschluss
3 weitere Nutzer haben diese Anleitung absolviert.
Josef
189 Reputation
1 Anleitung geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 39
Insgesamt: 4,331
