Zum Hauptinhalt wechseln
2002-2006 Acura Integra Hatch Strut Replacement
Was du brauchst
  1. 2002-2006 Acura Integra Hatch Strut Replacement, Hatch Strut: Schritt 1, Bild 1 von 1
  2. 2002-2006 Acura Integra Hatch Strut Replacement: Schritt 2, Bild 1 von 3 2002-2006 Acura Integra Hatch Strut Replacement: Schritt 2, Bild 2 von 3 2002-2006 Acura Integra Hatch Strut Replacement: Schritt 2, Bild 3 von 3
    • Go to the rear of the vehicle.
    • Pull up on the trunk handle to lift open the trunk.
  3. 2002-2006 Acura Integra Hatch Strut Replacement: Schritt 3, Bild 1 von 3 2002-2006 Acura Integra Hatch Strut Replacement: Schritt 3, Bild 2 von 3 2002-2006 Acura Integra Hatch Strut Replacement: Schritt 3, Bild 3 von 3
    • Prop open hatch or have someone help support the hatch weight.
    • Remove the upper ball mount.
    • Turn the upper ball mount counterclockwise with a 12mm wrench.
    • It will pop off when it's completely unscrewed.
  4. 2002-2006 Acura Integra Hatch Strut Replacement: Schritt 4, Bild 1 von 2 2002-2006 Acura Integra Hatch Strut Replacement: Schritt 4, Bild 2 von 2
    • Remove the lower ball mount.
    • Turn the lower ball mount counterclockwise with a 12mm wrench.
  5. 2002-2006 Acura Integra Hatch Strut Replacement: Schritt 5, Bild 1 von 3 2002-2006 Acura Integra Hatch Strut Replacement: Schritt 5, Bild 2 von 3 2002-2006 Acura Integra Hatch Strut Replacement: Schritt 5, Bild 3 von 3
    • Place a washer on the new upper ball mount.
    • Turn it clockwise to hand tighten the new upper ball mount.
    • Turn it clockwise with the crescent wrench to finish tightening.
  6. 2002-2006 Acura Integra Hatch Strut Replacement: Schritt 6, Bild 1 von 2 2002-2006 Acura Integra Hatch Strut Replacement: Schritt 6, Bild 2 von 2
    • Place a washer on the new lower ball mount.
    • Turn it clockwise to hand tighten the new lower ball mount.
    • Turn it clockwise with a crescent wrench to finish tightening the new lower ball mount.
  7. 2002-2006 Acura Integra Hatch Strut Replacement: Schritt 7, Bild 1 von 2 2002-2006 Acura Integra Hatch Strut Replacement: Schritt 7, Bild 2 von 2
    • Place a lower hatch strut socket over the new lower ball mount.
    • Push it firmly onto the new lower ball mount. It will pop on easily.
  8. 2002-2006 Acura Integra Hatch Strut Replacement: Schritt 8, Bild 1 von 1
    • Place the upper hatch strut socket over the new upper ball mount.
    • Press it firmly onto the new upper ball mount. It will pop on easily.
Abschluss
Michael Hagar
157 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 10
Insgesamt: 688
