Einleitung
This guide shows the process of replacing a hatch strut on a 2002-2006 Acura Integra (DC5 or RSX). A hatch strut, also referred to as a hatch lift support, is a vital component to keeping the hatch of a vehicle open. As they age and become worn out they’ll no longer function properly. In cold temperatures a worn hatch strut may even fail to keep the hatch open.
All that is needed are a replacement hatch strut, a 12mm wrench, and a crescent wrench. There is a wide variety of aftermarket hatch struts for this vehicle and there is no electrical work required for this fast fix. This guide utilizes a Monroe Max-Lift Lift Support. (Part Number: 900077) but any compatible replacement will suffice. It is recommended to have a helper stand by to hold the weight of the hatch or to safely prop it open during the replacement process. A simple fix like this can save you the time and money of going to a repair shop and helps build basic auto maintenance skills.
Was du brauchst
Acquire a compatible hatch strut (lift support). This guide uses a Monroe Max-Lift Lift Support. (Part Number: 900077)
Go to the rear of the vehicle.
Pull up on the trunk handle to lift open the trunk.
Remove the upper ball mount.
Turn the upper ball mount counterclockwise with a 12mm wrench.
Remove the lower ball mount.
Turn the lower ball mount counterclockwise with a 12mm wrench.
Place a washer on the new upper ball mount.
Turn it clockwise to hand tighten the new upper ball mount.
Turn it clockwise with the crescent wrench to finish tightening.
Place a washer on the new lower ball mount.
Turn it clockwise to hand tighten the new lower ball mount.
Turn it clockwise with a crescent wrench to finish tightening the new lower ball mount.
Place a lower hatch strut socket over the new lower ball mount.
Push it firmly onto the new lower ball mount. It will pop on easily.
Place the upper hatch strut socket over the new upper ball mount.
Press it firmly onto the new upper ball mount. It will pop on easily.
