Zum Hauptinhalt wechseln
2002-2006 Toyota Camry Key Fob Battery Replacement
Was du brauchst
  1. 2002-2006 Toyota Camry Key Fob Battery Replacement, Key Fob Battery: Schritt 1, Bild 1 von 2 2002-2006 Toyota Camry Key Fob Battery Replacement, Key Fob Battery: Schritt 1, Bild 2 von 2
    • Purchase a new lithium coin battery. You can find it at your local hardware store.
    • The battery has a "+" positive side (textured surface) and a "–" negative side (smooth surface).
  2. 2002-2006 Toyota Camry Key Fob Battery Replacement: Schritt 2, Bild 1 von 1
    • Use your hands or a spudger to separate the key fob into two pieces.
  3. 2002-2006 Toyota Camry Key Fob Battery Replacement: Schritt 3, Bild 1 von 1
    • Identify which part of the FOB holds the battery.
    • You will not need the other part of the fob until the end.
  4. 2002-2006 Toyota Camry Key Fob Battery Replacement: Schritt 4, Bild 1 von 2 2002-2006 Toyota Camry Key Fob Battery Replacement: Schritt 4, Bild 2 von 2
    • Remove the battery from the fob by releasing it from the holder using a spudger or by hand.
    • Be careful that you don't break the contacts when removing the battery.
  5. 2002-2006 Toyota Camry Key Fob Battery Replacement: Schritt 5, Bild 1 von 1
    • Insert the new battery by pushing it down.
  6. 2002-2006 Toyota Camry Key Fob Battery Replacement: Schritt 6, Bild 1 von 1
    • Reassemble the fob, using your hands to press the two parts together.
Abschluss
Salman Abu Mazen
140 Reputation
1 Anleitung geschrieben
UM-Willis-F21S51G7 Mitglied von UM-Willis-F21S51G7
Community
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 52
Letzte 30 Tage: 217
Insgesamt: 5,090
