Zum Hauptinhalt wechseln
2002 Ford F150 Crewcab Rear Door Latch Replacement
Was du brauchst
  1. 2002 Ford F150 Crewcab Rear Door Latch Replacement, Rear Door Latch: Schritt 1, Bild 1 von 3 2002 Ford F150 Crewcab Rear Door Latch Replacement, Rear Door Latch: Schritt 1, Bild 2 von 3 2002 Ford F150 Crewcab Rear Door Latch Replacement, Rear Door Latch: Schritt 1, Bild 3 von 3
    • Remove the Phillips #2 screws holding the window actuator mount to the door.
    • Place a wedge (or your finger) under the top part of the door cover. The cover will pull right off when all the clips are unlatched.
    • Be careful not to pull too hard, as the plastic could crack.
  2. 2002 Ford F150 Crewcab Rear Door Latch Replacement: Schritt 2, Bild 1 von 3 2002 Ford F150 Crewcab Rear Door Latch Replacement: Schritt 2, Bild 2 von 3 2002 Ford F150 Crewcab Rear Door Latch Replacement: Schritt 2, Bild 3 von 3
    • Once the top cover is off, remove the screws holding the lower door card on with a Phillips #2 screwdriver.
    • Once the lower door cover is removed it will expose the weather stripping.
    • Carefully pull the stripping back from the hinge corner depending on which door you are repairing.
    • In our case, it was the passenger rear door, so we pulled the weather stripping down from the top left corner to expose the latching mechanism.
  3. 2002 Ford F150 Crewcab Rear Door Latch Replacement: Schritt 3, Bild 1 von 3 2002 Ford F150 Crewcab Rear Door Latch Replacement: Schritt 3, Bild 2 von 3 2002 Ford F150 Crewcab Rear Door Latch Replacement: Schritt 3, Bild 3 von 3
    • As you can see here, the black cable in the back is worn and off of its track, this is the part we are replacing.
    • These are Dorman cable latch replacement fittings. Total they cost 12$
  4. 2002 Ford F150 Crewcab Rear Door Latch Replacement: Schritt 4, Bild 1 von 1
    • Take a pair of pliers and press on the halves of the fitting on the bracket.
    • Push the fitting through to release the cable clamp from the bracket.
    • You can pull the cable around the top to get a better view.
  5. 2002 Ford F150 Crewcab Rear Door Latch Replacement: Schritt 5, Bild 1 von 3 2002 Ford F150 Crewcab Rear Door Latch Replacement: Schritt 5, Bild 2 von 3 2002 Ford F150 Crewcab Rear Door Latch Replacement: Schritt 5, Bild 3 von 3
    • This is what wear on the cable looks like. This is the source of our problems.
    • The fitting has a groove through the middle of it.
    • Slide the cable through the middle groove so that it is seated in the fitting.
  6. 2002 Ford F150 Crewcab Rear Door Latch Replacement: Schritt 6, Bild 1 von 3 2002 Ford F150 Crewcab Rear Door Latch Replacement: Schritt 6, Bild 2 von 3 2002 Ford F150 Crewcab Rear Door Latch Replacement: Schritt 6, Bild 3 von 3
    • Press the fitting back into the bracket and grab it again with the pliers to make sure that it is seated properly.
    • Slide the bottom ridge of the fitting onto the bracket. You will see it positioned like this.
    • Test the door handle to make sure that the door opens and closes.
Abschluss
After the latch is fixed, test the door again and then follow steps 1 and 2 in reverse order to return the door back to working order.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 14
Letzte 30 Tage: 56
Insgesamt: 3,193
