Zum Hauptinhalt wechseln
2003-2015 Nissan Armada Cabin Air Filter Replacement
Was du brauchst
  1. 2003-2015 Nissan Armada Cabin Air Filter Replacement, Cabin Air Filter: Schritt 1, Bild 1 von 3 2003-2015 Nissan Armada Cabin Air Filter Replacement, Cabin Air Filter: Schritt 1, Bild 2 von 3 2003-2015 Nissan Armada Cabin Air Filter Replacement, Cabin Air Filter: Schritt 1, Bild 3 von 3
    • Open the glove box.
    • Use a Phillips #00 to remove the three screws at the top of the glove box.
    • Place your screws aside in a safe spot to use for reassembly.
    • Lift the glove box out.
  2. 2003-2015 Nissan Armada Cabin Air Filter Replacement: Schritt 2, Bild 1 von 3 2003-2015 Nissan Armada Cabin Air Filter Replacement: Schritt 2, Bild 2 von 3 2003-2015 Nissan Armada Cabin Air Filter Replacement: Schritt 2, Bild 3 von 3
    • Use a socket wrench to remove the 8 mm bolt securing the plastic cover to the cabin air filter.
    • Remove the plastic cover and you should see two air filters next to each other.
  3. 2003-2015 Nissan Armada Cabin Air Filter Replacement: Schritt 3, Bild 1 von 3 2003-2015 Nissan Armada Cabin Air Filter Replacement: Schritt 3, Bild 2 von 3 2003-2015 Nissan Armada Cabin Air Filter Replacement: Schritt 3, Bild 3 von 3
    • Carefully remove the filters starting with the left one as its easier to remove.
    • Now remove the one on the right side.
    • If you are struggling, use your fingers to slide it over.
    • Place the dirty air filters to the side and have the new ones ready.
  4. 2003-2015 Nissan Armada Cabin Air Filter Replacement: Schritt 4, Bild 1 von 3 2003-2015 Nissan Armada Cabin Air Filter Replacement: Schritt 4, Bild 2 von 3 2003-2015 Nissan Armada Cabin Air Filter Replacement: Schritt 4, Bild 3 von 3
    • Place the first filter to the right side with the airflow arrows pointing down.
    • Insert the second air filter, to the left of the first filter.
Abschluss
Kenneth Maldonado
109 Reputation
1 Anleitung geschrieben
Austin Community College, Team 1-8, Watkins Fall 2023 Mitglied von Austin Community College, Team 1-8, Watkins Fall 2023
AUSTINCC-WATKINS-F23S1G8
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 24
Letzte 30 Tage: 91
Insgesamt: 382
