Zum Hauptinhalt wechseln
Diese Übersetzung enthält möglicherweise noch nicht die neuesten Änderungen der Original-Anleitung. Hilf mit, die Übersetzung zu aktualisieren oder sieh dir die Original-Anleitung an.
2003-2008 Toyota Corollaのヒューズボックスを見つける
Was du brauchst
  1. 2003-2008 Toyota Corollaのヒューズボックスを見つける, 2003-2008 Toyota Corollaのヒューズボックスを見つける: Schritt 1, Bild 1 von 1
    • 左側のパネルの真下にヒューズボックスがあります。(イギリスのモデルは場所が異なります)黒い四角の箱なので、適切な道具を使って外す必要があります。
  2. 2003-2008 Toyota Corollaのヒューズボックスを見つける: Schritt 2, Bild 1 von 1
    • 箱のカバーを外した後、ヒューズを交換します。私の場合、38番でした。(フィールダー・モデルの場合は異なります)詳細はヒューズの略図が書いてあるユーザーマニュアルをご覧ください。
Abschluss
デバイスを組み立て直すには、これらの手順と逆の順序に従ってください。
24 weitere Nutzer:innen haben diese Anleitung absolviert.
en jp
75%
Hier starten ›
27 Kommentare
Will this work for Toyota Rukus as we have on our website http://www.toyotarukusclub.com too?
James Wools - Antwort
1. This doesn't actually show anything about where it is or how you got to it.
2. The only "black box" in any of your photos is the dead pedal, which is definitely not where the fuses are.
How is this page the top result for toyota corolla fuse box in Google?
Dinksmack - Antwort
Guys, the 2004 Corolla Japan made, the internal fuse panel does not locate behind the coins tray.
you must lay down on the floor of the car on driver side (hard due to less room), look up under the dash board you will find very samll black plastic cover (1 inch wide and 4 inches long), you may need a flash light, open this cover by press the letch which is located only your left hand side by laying down on the ground.
This is a verse thing ever I saw in Toyota, this fuse pannel is very hard to work, even the fuse diagram/location mentioned behind the cover is wrong as well. I just need to replace the power window fuse which was mentioned on the cover location at a wrong place, I found the menual was help full to find the location for the correct fuse only.
Hope it will help full and sorry for the typo if any.
Shahbaz -
Dink. I’m so glad someone said it. I was just about to start yelling at my monitor.
gallain -
I finally found a forum that helped me fixed my ac not blowing hot air issue. I thought at first my compressor went out, the relay was burned from under the hood and I replaced that with no success, I even used the horn relay with no success. I tested the wiring and looked at every freakin thing. I too did not find the interior fuse box behind the coin box. It was there but way the f**k under the dashboard as the previous comment mentioned. I finally found the #24 fuse 10 Amp was burned up. I replaced it and that wonderful cold air came out once again. I almost took this car to a mechanic and I knew it would cost a pretty penny. Hope this helps the next fellow.
crgarcia68 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 66
Letzte 7 Tage: 545
Letzte 30 Tage: 2,364
Insgesamt: 337,949
