Zum Hauptinhalt wechseln
2003-2006 Chevrolet Silverado Headlight Bulb Replacement
Was du brauchst
  1. 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Preparation: Schritt 1, Bild 1 von 3 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Preparation: Schritt 1, Bild 2 von 3 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Preparation: Schritt 1, Bild 3 von 3
    • Turn your vehicle off, and let the engine bay cool before starting the following steps.
    • First, open the driver side door, and reach under the steering wheel and release the latch to open up the hood of your truck.
    • Next, walk over to either of the headlights and remove the pin above the headlight to release the housing unit.
    • Make sure to put the pin in a safe location so you can lock in the housing once you finish replacing the light bulbs.
  2. 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Removing the old lights: Schritt 2, Bild 1 von 3 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Removing the old lights: Schritt 2, Bild 2 von 3 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Removing the old lights: Schritt 2, Bild 3 von 3
    • Pinch the blue clips and remove them from the back of the wiring harness.
    • After removing the pin, you should now be able to tilt the headlight downward to gain access to all of the wires.
    • Twist the light bulb counter clockwise and gently remove the harness and the light bulb.
  3. 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Inserting the new lightbulb: Schritt 3, Bild 1 von 3 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Inserting the new lightbulb: Schritt 3, Bild 2 von 3 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Inserting the new lightbulb: Schritt 3, Bild 3 von 3
    • Unbox your new low beam light, and insert it into the same hole you took the old one out of.
    • Be sure to twist the bulb clockwise until it locks into place with the harness pointing down.
    • Plug the blue wiring harness back in until you hear a click, and it should now be locked back into place.
  4. 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Putting the headlight in: Schritt 4, Bild 1 von 3 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Putting the headlight in: Schritt 4, Bild 2 von 3 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Putting the headlight in: Schritt 4, Bild 3 von 3
    • Begin to replace the headlight housing back into its original place by tucking in the wires.
    • Grab the pin that you took out at the beginning and insert it back into the housing unit.
    • Align the housing back with the guide holes for the pin.
  5. 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Repeat: Schritt 5, Bild 1 von 2 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Repeat: Schritt 5, Bild 2 von 2
    • Follow steps 1-4 for the other headlight to replace the low beam headlight.
    • Make sure to keep track of all of your parts and dispose of your old bulbs properly.
    • Be sure to check your headlight alignment. This can be done by a professional or through Youtube videos.
Abschluss
To replace the other light bulb just follow the same steps as above.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Sam Houston State, Team 16-3, Nardone Fall 2015 Mitglied von Sam Houston State, Team 16-3, Nardone Fall 2015
SHSU-NARDONE-F15S16G3
4 Mitglieder
1 Anleitung geschrieben
Ein Kommentar
FYI: don't touch the bulbs with bare hands. The oil from your fingers will cause them to burn out early.
Jay Wilhoite - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 22
Letzte 30 Tage: 70
Insgesamt: 41,520
