Zum Hauptinhalt wechseln
2003 Chevrolet Cavalier Engine Air Filter Replacement
Was du brauchst
  1. 2003 Chevrolet Cavalier Engine Air Filter Replacement, Engine Air Filter: Schritt 1, Bild 1 von 2 2003 Chevrolet Cavalier Engine Air Filter Replacement, Engine Air Filter: Schritt 1, Bild 2 von 2
    • Pull the hood release lever.
    • This lever is located inside the cabin of the car to the left of the pedals.
  2. 2003 Chevrolet Cavalier Engine Air Filter Replacement: Schritt 2, Bild 1 von 2 2003 Chevrolet Cavalier Engine Air Filter Replacement: Schritt 2, Bild 2 von 2
    • Pull up on the hood slightly and lift the safety latch.
    • The hood will not open unless the safety latch has been lifted.
  3. 2003 Chevrolet Cavalier Engine Air Filter Replacement: Schritt 3, Bild 1 von 2 2003 Chevrolet Cavalier Engine Air Filter Replacement: Schritt 3, Bild 2 von 2
    • Open the hood and hold it with one hand.
    • Grab the prop rod in the other hand.
    • Insert the prop rod into one of the slots in the hood to secure it in place.
    • Make sure the prop rod is secure in the slot otherwise the hood may fall.
  4. 2003 Chevrolet Cavalier Engine Air Filter Replacement: Schritt 4, Bild 1 von 3 2003 Chevrolet Cavalier Engine Air Filter Replacement: Schritt 4, Bild 2 von 3 2003 Chevrolet Cavalier Engine Air Filter Replacement: Schritt 4, Bild 3 von 3
    • Unclip the wiring harness from the retaining clamps with a flathead screwdriver.
    • Pull the wiring harness out of the clamps.
  5. 2003 Chevrolet Cavalier Engine Air Filter Replacement: Schritt 5, Bild 1 von 2 2003 Chevrolet Cavalier Engine Air Filter Replacement: Schritt 5, Bild 2 von 2
    • Unscrew the four cover-mounting screws holding the air filter cover on.
    • The screws do not come out of the filter housing.
  6. 2003 Chevrolet Cavalier Engine Air Filter Replacement: Schritt 6, Bild 1 von 1
    • Separate the housing halves to access the air filter element.
  7. 2003 Chevrolet Cavalier Engine Air Filter Replacement: Schritt 7, Bild 1 von 3 2003 Chevrolet Cavalier Engine Air Filter Replacement: Schritt 7, Bild 2 von 3 2003 Chevrolet Cavalier Engine Air Filter Replacement: Schritt 7, Bild 3 von 3
    • Remove the old air filter.
    • Place the new filter in the housing.
    • The new air filter will sit comfortably in place without wobbling.
Abschluss
Dawson Stroik
145 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 209
