Einleitung
Toyota Matrix 2003 automatic transmission speed sensor might be known as also: transaxle speed sensor, vehicle speed sensor (VSS). Thank you, vibeusa on Toyota Nation Forum, for sharing speed sensor location with diagram (2014-02-20 : Transmission VSS location?).
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Transaxle is behind and below engine. You will have a hard time seeing it if your height is less than 170 cm. If you are two metres tall or taller, then it will be easy to see.
Some guides instruct to remove air filter, though I find that needless and not beneficial.
Disconnect sensor now, or disconnect it later. You might find it easier to unplug sensor after removing it from transaxle, when it is less far away from you, then easier to reach.
Press on ridged tab to release clip/latch. Grip connector, not wires, and pull it off of sensor.
Transaxle speed sensor is fastened down with one screw, 12mm hexagon head. Use a socket on a long shaft to reach. Just sixteen inches is long enough, also one half yard or half metre works.
Observe the dimple in original screws which hold sensor together: these are JIS size 1 cruciform drive. This observation is only meant to be interesting or informative, not relevant to guide.
3 weitere Nutzer haben diese Anleitung absolviert.
2 Kommentare
Wire assignments in piece pictured: yellow is +12 volt, brown is 0 volt, green+white wire is output signal.
I have a 2003 toyota matrix xr awd and I looked where you told me too and unfortunately the speed sensor was not there. I also bought the manual for it that is for repairs and it showed the same location as of where you were showing and I am dealing with the same problem, no speed sensor.
