Zum Hauptinhalt wechseln
2003 Toyota Solara Tail Light Replacement
Was du brauchst
  1. 2003 Toyota Solara Tail Light Replacement, Tail Light: Schritt 1, Bild 1 von 1
    • Park the vehicle and turn off the engine.
    • Step on the brake pedal to confirm whether or not the tail light is responsive.
  2. 2003 Toyota Solara Tail Light Replacement: Schritt 2, Bild 1 von 3 2003 Toyota Solara Tail Light Replacement: Schritt 2, Bild 2 von 3 2003 Toyota Solara Tail Light Replacement: Schritt 2, Bild 3 von 3
    • Reach underneath the steering wheel. Then, place your hand to the left to remove the fuse box cover.
  3. 2003 Toyota Solara Tail Light Replacement: Schritt 3, Bild 1 von 2 2003 Toyota Solara Tail Light Replacement: Schritt 3, Bild 2 von 2
    • Reference the fuse box guide on the back of the cover.
    • Locate the fuse number that corresponds to the tail light (2nd column, last row).
    • Replace the tail lamp if the fuse is still functional.
  4. 2003 Toyota Solara Tail Light Replacement: Schritt 4, Bild 1 von 2 2003 Toyota Solara Tail Light Replacement: Schritt 4, Bild 2 von 2
    • Open the vehicle's trunk.
    • Unscrew the plastic fastenings located inside the trunk.
    • Detach the panel covering the tail light.
  5. 2003 Toyota Solara Tail Light Replacement: Schritt 5, Bild 1 von 3 2003 Toyota Solara Tail Light Replacement: Schritt 5, Bild 2 von 3 2003 Toyota Solara Tail Light Replacement: Schritt 5, Bild 3 von 3
    • Untwist the wired socket to expose the lamp bulb.
    • Check the bulb for discoloration (if it is clouded, replace the bulb).
  6. 2003 Toyota Solara Tail Light Replacement: Schritt 6, Bild 1 von 2 2003 Toyota Solara Tail Light Replacement: Schritt 6, Bild 2 von 2
    • Insert the new bulb into the socket.
    • Push until there is an audible "click".
Abschluss
To reassemble the tail lamp, follow these instructions in reverse order.
3 weitere Personen haben diese Anleitung absolviert.
UC Davis, Team S2-G2, Cole Spring 2017 Mitglied von UC Davis, Team S2-G2, Cole Spring 2017
UCD-COLE-S17S2G2
3 Mitglieder
1 Anleitung geschrieben
1Leitfaden Kommentar
How to replace the rear mount light in the rear windows of a 2009 toyota corolla
lincoln mcgill - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 18
Letzte 30 Tage: 115
Insgesamt: 3,371
