Zum Hauptinhalt wechseln
2004-2012 Nissan Versa Interior Dome Light Replacement
Was du brauchst
  1. 2004-2012 Nissan Versa Interior Dome Light Replacement, Interior Dome Light: Schritt 1, Bild 1 von 3 2004-2012 Nissan Versa Interior Dome Light Replacement, Interior Dome Light: Schritt 1, Bild 2 von 3 2004-2012 Nissan Versa Interior Dome Light Replacement, Interior Dome Light: Schritt 1, Bild 3 von 3
    • Take off the inner dome light's plastic covering. Either with an opening tool or your hands.
    • It is suggested that you use a flathead screwdriver due to the pressure you need to use with your hands; nevertheless, exercise caution when using your hands to avoid breaking the lid and/or clips.
  2. 2004-2012 Nissan Versa Interior Dome Light Replacement: Schritt 2, Bild 1 von 1
    • Locate the bulb in the middle of the outlet.
    • Should it remain hot, give it a minute or so too cool down before removing the lightbulb.
    • Prior to removing the light bulb, be sure it is not hot.
  3. 2004-2012 Nissan Versa Interior Dome Light Replacement: Schritt 3, Bild 1 von 3 2004-2012 Nissan Versa Interior Dome Light Replacement: Schritt 3, Bild 2 von 3 2004-2012 Nissan Versa Interior Dome Light Replacement: Schritt 3, Bild 3 von 3
    • Push the tab away from the bulb to release the bulb.
  4. 2004-2012 Nissan Versa Interior Dome Light Replacement: Schritt 4, Bild 1 von 3 2004-2012 Nissan Versa Interior Dome Light Replacement: Schritt 4, Bild 2 von 3 2004-2012 Nissan Versa Interior Dome Light Replacement: Schritt 4, Bild 3 von 3
    • Replace the dead or broken bulb with a new bulb by inserting a side in the hole first then pushing it upwards past the tab to seal it inside.
    • The socket for a 2012 Nissan Versa is a DE3175 bulb.
    • In order to prevent burns, turn off the power supply before changing the lightbulb.Because the light bulb is fragile, you should use caution when inserting it into the socket to avoid breaking it.
  5. 2004-2012 Nissan Versa Interior Dome Light Replacement: Schritt 5, Bild 1 von 3 2004-2012 Nissan Versa Interior Dome Light Replacement: Schritt 5, Bild 2 von 3 2004-2012 Nissan Versa Interior Dome Light Replacement: Schritt 5, Bild 3 von 3
    • Make sure the lightbulb and socket are operational by turning on the light by pushing the switch.
    • (If it is successful, your light ought to shine like the ones in the pictures.)
  6. 2004-2012 Nissan Versa Interior Dome Light Replacement: Schritt 6, Bild 1 von 3 2004-2012 Nissan Versa Interior Dome Light Replacement: Schritt 6, Bild 2 von 3 2004-2012 Nissan Versa Interior Dome Light Replacement: Schritt 6, Bild 3 von 3
    • To put the clear cover back you insert the side with one large hinge to the open space hinge.
    • The light assembly has a hinge, which clips back in
  7. 2004-2012 Nissan Versa Interior Dome Light Replacement: Schritt 7, Bild 1 von 2 2004-2012 Nissan Versa Interior Dome Light Replacement: Schritt 7, Bild 2 von 2
    • Once the lid is pressed into place with your fingertips till you hear a click to indicate you sealed it, your car will be illuminated by a new light.
Abschluss
Pamela Villalon
145 Reputation
1 Anleitung geschrieben
Sam Houston State, Team 1-3, Bennett Fall 2023 Mitglied von Sam Houston State, Team 1-3, Bennett Fall 2023
SHSU-BENNETT-F23S1G3
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 17
Letzte 30 Tage: 76
Insgesamt: 343
