Zum Hauptinhalt wechseln
2004-2008 Ford F150 Tail Light Bulb Replacement
Was du brauchst
  1. 2004-2008 Ford F150 Tail Light Bulb Replacement, Tail Light Bulb: Schritt 1, Bild 1 von 1
    • Park the vehicle on a level surface.
    • Turn the vehicle off.
    • If the vehicle is not turned off, there is a risk of electrocution upon removal of the tail light.
  2. 2004-2008 Ford F150 Tail Light Bulb Replacement: Schritt 2, Bild 1 von 1
    • Lower the tailgate.
  3. 2004-2008 Ford F150 Tail Light Bulb Replacement: Schritt 3, Bild 1 von 3 2004-2008 Ford F150 Tail Light Bulb Replacement: Schritt 3, Bild 2 von 3 2004-2008 Ford F150 Tail Light Bulb Replacement: Schritt 3, Bild 3 von 3
    • Use the 8mm socket wrench to remove both of the mounting bolts.
    • An 8mm crescent wrench can be used in place of the 8mm socket wrench.
  4. 2004-2008 Ford F150 Tail Light Bulb Replacement: Schritt 4, Bild 1 von 2 2004-2008 Ford F150 Tail Light Bulb Replacement: Schritt 4, Bild 2 von 2
    • Remove the tail light by pulling the tail light housing straight back, away from the vehicle.
    • If the tail light housing is too difficult to remove use a thin, stiff piece of plastic as a pry bar to aid in removing the tail light housing.
    • If a pry bar is used, take caution to not scratch the paint of the vehicle.
  5. 2004-2008 Ford F150 Tail Light Bulb Replacement: Schritt 5, Bild 1 von 1
    • Twist the upper socket counter clockwise.
    • Pull back to remove the socket from the tail light assembly.
  6. 2004-2008 Ford F150 Tail Light Bulb Replacement: Schritt 6, Bild 1 von 2 2004-2008 Ford F150 Tail Light Bulb Replacement: Schritt 6, Bild 2 von 2
    • Pull the bulb out of the socket.
    • When handling the replacement bulb, be careful to minimize contact with the bulb itself; as the oils from your hand can decrease the lifespan of the bulb.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Eric Carnes
274 Reputation
1 Anleitung geschrieben
Washington State, Team S1-G5, Hope Summer 2018 Mitglied von Washington State, Team S1-G5, Hope Summer 2018
WSU-HOPE-SU18S1G5
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 15
Letzte 30 Tage: 70
Insgesamt: 10,362
