Einleitung
This replacement guide will teach you how to how to replace the battery, safely, in a few easy steps.
Was du brauchst
Find black tabs that lock Battery cover into place.
The tabs should snap off easily.
Use the 10 mm wrench to disconnect the negative battery terminal, followed by the positive terminal.
Remove the terminals once nuts are completely loose.
After replacing the device, follow these instructions in reverse order to secure a new battery in its place.
2 weitere Personen haben diese Anleitung absolviert.
