Zum Hauptinhalt wechseln
2004-2008 Mazda RX-8 Tire Rotation
Was du brauchst
  1. 2004-2008 Mazda RX-8 Tire Rotation, 2004-2008 Mazda RX-8 Tire Rotation: Schritt 1, Bild 1 von 1
    • Loosen lug nuts with the socket/wrench just until they begin to turn.
    • Removing lug nuts requires a 21mm socket.
  2. 2004-2008 Mazda RX-8 Tire Rotation: Schritt 2, Bild 1 von 3 2004-2008 Mazda RX-8 Tire Rotation: Schritt 2, Bild 2 von 3 2004-2008 Mazda RX-8 Tire Rotation: Schritt 2, Bild 3 von 3
    • Place Jack under the car (as shown).
    • It's best to avoid using the jack included with the car. If at all possible, use at least a 2 ton floor jack.
    • Use the Jack Handle to crank up just enough so that the tire noticeably lifts off the ground.
  3. 2004-2008 Mazda RX-8 Tire Rotation: Schritt 3, Bild 1 von 1
    • Put the jack stand under the car to ensure the car will not fall back down while you are working on it.
  4. 2004-2008 Mazda RX-8 Tire Rotation: Schritt 4, Bild 1 von 1
    • Remove all lug nuts holding the wheel on the car.
  5. 2004-2008 Mazda RX-8 Tire Rotation: Schritt 5, Bild 1 von 1
    • Remove the front wheel from the vehicle.
  6. 2004-2008 Mazda RX-8 Tire Rotation: Schritt 6, Bild 1 von 1
    • With the front wheel off repeat step 4 and step 5 to remove the rear wheel as well.
  7. 2004-2008 Mazda RX-8 Tire Rotation: Schritt 7, Bild 1 von 1
    • Place the rear wheel on the front of the car and place the front wheel in the rear. Tighten up the lug nuts and your tire rotation is complete.
    • Begin to tighten the lug nuts as much as you can with the wheel in the air, and then lower the car to the ground to finish tightening.
    • Tighten the nuts in a star pattern to avoid over tightening one side leaving the wheel installed crooked
    • Mazda recommends that the lug nuts be torqued to 108 ft*lbs to ensure that the wheel is secure
Abschluss
Verify a second time that every piece nut is secure and tight. You may have to do this again in the future.
Gerrit Mouw
253 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 8-4, Regan Spring 2015 Mitglied von Cal Poly, Team 8-4, Regan Spring 2015
CPSU-REGAN-S15S8G4
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 32
Insgesamt: 2,480
