Zum Hauptinhalt wechseln
2004 Honda Pilot Timing Belt Replacement
Was du brauchst
  1. 2004 Honda Pilot Timing Belt Replacement, Timing Belt: Schritt 1, Bild 1 von 1
    • Looking from above showing the accessory belts removed along with the motor mount.
  2. 2004 Honda Pilot Timing Belt Replacement: Schritt 2, Bild 1 von 1
    • Side view showing same including the lower cover
  3. 2004 Honda Pilot Timing Belt Replacement: Schritt 3, Bild 1 von 1
    • Crank pulley bolt removal (loosen the bolt before removing the motor mount!)
  4. 2004 Honda Pilot Timing Belt Replacement: Schritt 4, Bild 1 von 1
    • Lower cover showing crank end and lower part of the dipstick tube (hydraulic tensioner can be seen behind VTEC solenoid) (crank timing mark can also be seen)
  5. 2004 Honda Pilot Timing Belt Replacement: Schritt 5, Bild 1 von 1
    • Upper and lower covers removed (12mm power steering adjuster nut shown)
  6. 2004 Honda Pilot Timing Belt Replacement: Schritt 6, Bild 1 von 1
    • Lower cover removed (rubber plug in the dipstick opening to prevent trash from falling in)
  7. 2004 Honda Pilot Timing Belt Replacement: Schritt 7, Bild 1 von 1
    • Different angle to show both 14mm pulley bolts
  8. 2004 Honda Pilot Timing Belt Replacement: Schritt 8, Bild 1 von 1
    • Top view showing timing belt, tensioner, and pulleys off
  9. 2004 Honda Pilot Timing Belt Replacement: Schritt 9, Bild 1 von 1
    • Top view showing water pump. Also showing the belt, pulleys, and tensioner removed
  10. 2004 Honda Pilot Timing Belt Replacement: Schritt 10, Bild 1 von 1
    • Bottom view showing the belt, pulleys, and tensioner removed
  11. 2004 Honda Pilot Timing Belt Replacement: Schritt 11, Bild 1 von 1
    • Bolt (silver one closer to the front of the block) with thread lock
  12. 2004 Honda Pilot Timing Belt Replacement: Schritt 12, Bild 1 von 1
    • Old parts and removed parts
  13. 2004 Honda Pilot Timing Belt Replacement: Schritt 13, Bild 1 von 1
    • Old parts, lower cover, motor mount
  14. 2004 Honda Pilot Timing Belt Replacement: Schritt 14, Bild 1 von 1
    • Covers, mount, dipstick (and new o-ring)
  15. 2004 Honda Pilot Timing Belt Replacement: Schritt 15, Bild 1 von 1
    • Various tools used (bag shows the part number for the trim clips)
Abschluss
This job is a great example where parts are cheap and labor is expensive. If you are able to do this yourself you can easily save 80% of your bill.
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 41
Insgesamt: 3,592
