Einleitung
The guide covers the replacement of Lexus 330 RX 2004 battery. This guide can be used when the battery is dead or damaged. Battery are dangerous, use extreme caution during all the steps of this guide.
Was du brauchst
Pull up the lever underneath the steering wheel to pop up the hood.
Unlatch the hood.
The battery should be located on the lower right side of engine.
Use a wrench with a 10 mm socket to remove the bolts of the bracket.
Repeat the step above for the second bolt.
Remove the bolts on the clamps with a 10 mm socket.
Repeat the process on the second terminal of the battery.
Place the bracket back on top of the battery.
Use a wrench with a 10 mm socket to secure the bolts of the bracket.
Repeat the above step for the second bolt.
Put the terminal back on.
Put the bolts on the clamps back on with a 10 mm socket.
Repeat the previous step for the second bolt.
You have successfully changed the battery of Lexus 330 RX 200. Good Job!
5 weitere Personen haben diese Anleitung absolviert.
