Zum Hauptinhalt wechseln
2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly
Was du brauchst
  1. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly, Stereo Unit: Schritt 1, Bild 1 von 1
    • This is the front panel of the 2004 Mazda 3 Stereo-CD Player. It's listed under the model number: BN85-66-9RXA.
  2. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: Schritt 2, Bild 1 von 1
    • On the right side of the unit, designated by the letter R, remove 6 screws using a Phillips #2 screwdriver.
  3. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: Schritt 3, Bild 1 von 1
    • On the left side of unit, designated by the letter L, remove 6 screws using a Phillips #2 screwdriver.
    • Gently pull on the cable to disconnect it from the front panel.
    • Now you can fully detach the front panel as well as the LCD display from the unit.
  4. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: Schritt 4, Bild 1 von 1
    • On the top of the unit, remove 2 screws with a Phillips #2 screwdriver.
    • Lift and remove the top case from the unit.
  5. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: Schritt 5, Bild 1 von 1
    • On the bottom of the unit, remove 2 screws with the Phillips #2 screwdriver.
  6. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: Schritt 6, Bild 1 von 1
    • On the back of the unit, remove 8 screws with a Phillips #2 screwdriver.
    • Remove 1 screw with a Phillips #1 screwdriver.
    • Pull off both the bottom and top metal plates.
  7. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: Schritt 7, Bild 1 von 1
    • On the front of the unit, remove 4 screws with a Phillips #2 screwdriver.
  8. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: Schritt 8, Bild 1 von 1
    • On the left side of the unit, designated by the letter L, remove 2 screws with a Phillips #2 screwdriver.
  9. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: Schritt 9, Bild 1 von 1
    • On the right side of the unit, designated by the letter R, remove 2 screws with a Phillips #2 screwdriver.
    • Pull the front metal plate off the unit. Then lift the CD drive from the lower metal case.
  10. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly, CD Drive: Schritt 10, Bild 1 von 1
    • Remove 2 screws with a Phillips #1 screwdriver from the front of the CD drive.
    • Very gently pull apart the top metal case from the CD drive without damaging the ribbon cable.
  11. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: Schritt 11, Bild 1 von 1
    • Gently pull the ribbon cable from the connector on the CD drive logic board.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Robin Nystrom
182 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 17
Letzte 30 Tage: 54
Insgesamt: 5,018
