Einleitung
In this guide we will simply replace the window of the vehicle in the easiest way possible for the average person who may have little experience in fixing or dealing with cars. With enough patience, anyone could do this fix and save tons of money, as opposed to taking it to a dealership or repair shop, where the costs of repair would be much higher.
Was du brauchst
Roll down the window.
Remove the 3 exposed screws on the plastic door panel using the Phillips #3 Screwdriver.
Remove the red reflector at the top edge of the door panel using a flathead screwdriver.
Unscrew the screw beneath the reflector using the 5/32 Allen key.
Once the door panel has been popped off, use both hands and set it aside carefully.
Remove the 3 screws holding the speaker in place using the Phillips #3 screwdriver.
Lift the speaker out and set it nearby, being careful not to pull excessively on the wire connected to it.
Remove two screws, one in the bottom-left corner of the door panel and the other in the speaker hole, with a 5/32 Allen key.
Roll the window up after loosening the roller screws in the previous step.
After rolling up the window, simply use two hands to carefully remove the window.
Roll the window down at least 1/4 of an inch and then place new window in between the rollers.
Roll down the window all the way again and replace the two screws in the bottom-left corner and speaker hole with the 5/32 Allen key to secure the window rollers.
Place the speaker back in the door panel and replace the three screws to secure it using the Phillips #3 Screwdriver.
Align the door panel and the metal frame of the door, then using a mallet or your hand, pop the panel back into place carefully.
Using the Phillips #3 Screwdriver, screw in the three side panel screws back into place.
Screw on the fourth screw on the door panel using the Phillips #3 Screwdriver.
Snap on the red reflector using your hand. Again, not too much pressure is need, as excess pressure may cause the red reflector to crack.
Snap on the handle and speaker cover using your hand. And once, again, use enough pressure to snap it back in place, and not excess pressure.
