Einleitung
If you are looking to replace the passenger side window for a 2004 Toyota 4Runner use this guide to fix it.
Fixing the window of your car can seem awfully difficult but with this guide, it can be easily done in under an hour. There are several reasons why you might need this guide. If your car window is loose and dislodges whenever you roll it up or down, you can use this guide to put it back in place. If your previous window was shattered and you want to install a new one, this guide is just for you. (If your previous glass was shattered make sure to clean up any glass shards before installing the new glass.)
Before beginning, be sure to turn off the ignition, place the car in park, and engage the parking brake.
Was du brauchst
Prop the door open.
Using an upholstery remover, remove the plastic cap.
Using a hook tool, remove the plastic panel behind the door handle.
Remove the armrest using a trim panel removal tool.
Remove the light using an upholstery remover.
Disconnect the lights by applying pressure on the clip and pulling outwards.
Lift the door panel carefully off of the door.
Disconnect the green and white wires by pulling outward with your fingers.
Disconnect the wires by applying pressure to the sides of the white clip and pulling with your fingers.
Remove the four screws using a Phillips #0 screwdriver.
Disconnect the speaker by pulling out the white wires.
