Zum Hauptinhalt wechseln
2005-2012 Toyota RAV4 Headlight Replacement
  1. 2005-2012 Toyota RAV4 Headlight Replacement, Headlight: Schritt 1, Bild 1 von 1
    • Turn off your car, use your emergency break to secure the car and pop open the hood.
    • Make sure the engine is not hot before working under the hood of the car.
  2. 2005-2012 Toyota RAV4 Headlight Replacement: Schritt 2, Bild 1 von 2 2005-2012 Toyota RAV4 Headlight Replacement: Schritt 2, Bild 2 von 2
    • Under the hood of the car, locate a black cable towards the grille on the drivers side that leads to the back of the headlight. The bulb is located here.
  3. 2005-2012 Toyota RAV4 Headlight Replacement: Schritt 3, Bild 1 von 3 2005-2012 Toyota RAV4 Headlight Replacement: Schritt 3, Bild 2 von 3 2005-2012 Toyota RAV4 Headlight Replacement: Schritt 3, Bild 3 von 3
    • Turn the bulb counter-clockwise using your hand and gently pull the headlight out.
  4. 2005-2012 Toyota RAV4 Headlight Replacement: Schritt 4, Bild 1 von 2 2005-2012 Toyota RAV4 Headlight Replacement: Schritt 4, Bild 2 von 2
    • The headlight is attached to a plug that has a clip. Push down on the clip and pull the bulb out at the same time with the opposite hand.
  5. 2005-2012 Toyota RAV4 Headlight Replacement: Schritt 5, Bild 1 von 3 2005-2012 Toyota RAV4 Headlight Replacement: Schritt 5, Bild 2 von 3 2005-2012 Toyota RAV4 Headlight Replacement: Schritt 5, Bild 3 von 3
    • Slide the new bulb into that same plug until you hear a click.
  6. 2005-2012 Toyota RAV4 Headlight Replacement: Schritt 6, Bild 1 von 2 2005-2012 Toyota RAV4 Headlight Replacement: Schritt 6, Bild 2 von 2
    • Put the bulb into the same hole that it was removed from and turn clockwise until you hear another click. You are done!
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
1 Kommentar zur Anleitung
This is a headlight BULB replacement, not a headlight replacement. Please consider changing the title, which is misleading. Thank you.
Barb - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 58
Letzte 30 Tage: 224
Insgesamt: 15,942
