Zum Hauptinhalt wechseln
2005-2007 Ford Focus Oil Change
Was du brauchst
  1. 2005-2007 Ford Focus Oil Change, Preparation: Schritt 1, Bild 1 von 2 2005-2007 Ford Focus Oil Change, Preparation: Schritt 1, Bild 2 von 2
    • Use ramps or jack stands to raise the front of the car and chock the rear wheels to keep the car from moving.
    • Remove the oil filler cap by rotating it 1/4 turn counterclockwise and lifting it off the valve cover.
  2. 2005-2007 Ford Focus Oil Change, Drain the Old Oil: Schritt 2, Bild 1 von 3 2005-2007 Ford Focus Oil Change, Drain the Old Oil: Schritt 2, Bild 2 von 3 2005-2007 Ford Focus Oil Change, Drain the Old Oil: Schritt 2, Bild 3 von 3
    • Locate the oil pan drain plug underneath the car. It is a 13 mm hex bolt that faces towards the rear of the car.
    • Place an oil drain pan underneath the oil pan to catch the draining oil. Remember to place it towards the rear of the car, since the oil will come out of the oil pan in a stream.
    • Be very cautious when working under a car that has been running recently, because the oil pan and transmission will be very hot.
    • Loosen the oil pan drain plug with a 13 mm socket wrench until it comes off and oil is draining out of the oil pan.
    • Watch for shiny specks in the draining oil. Small metal flakes could mean a serious problem inside your engine.
  3. 2005-2007 Ford Focus Oil Change, Flush Out Any Remaining Old Oil: Schritt 3, Bild 1 von 1
    • This step is only necessary if you wish to flush all of the old oil from your engine. You may consider doing this if it has been an especially long time since your last oil change or if some foreign liquid has been poured into the filler hole.
    • Place a funnel in the oil fill hole in the valve cover.
    • Pour a quart of oil into the funnel and let all of it drain and collect in the oil drain pan.
    • Since very little of this oil will remain in your engine, you may want to use the least expensive oil you can find for this.
  4. 2005-2007 Ford Focus Oil Change, Finish Up Oil Pan and Move to the Oil Filter: Schritt 4, Bild 1 von 1
    • Wipe off and replace the oil pan drain plug. Use a moderate amount of force, but do not over-tighten the bolt.
    • You can always tighten the bolt more if you notice oil leaking from the plug. A cracked oil pan, however, is a much more expensive repair.
    • Position the oil drain pan underneath the oil filter.
  5. 2005-2007 Ford Focus Oil Change, Removing the Old Oil Filter: Schritt 5, Bild 1 von 3 2005-2007 Ford Focus Oil Change, Removing the Old Oil Filter: Schritt 5, Bild 2 von 3 2005-2007 Ford Focus Oil Change, Removing the Old Oil Filter: Schritt 5, Bild 3 von 3
    • Turn the oil filter counterclockwise (when looking up at it) to remove it.
    • If your filter is on too tight to loosen by hand, you may need to use an oil filter wrench or belt wrench to remove it.
    • Oil will begin to run down the sides of the oil filter. It is up to your discretion to either let it drain slowly this way or take the filter off quickly. Keep in mind that no matter what, the filter itself will still have oil in it that must be drained.
    • Set the old filter in your oil drain pan with the gasket facing down to allow the oil to drain out of it.
    • Once the oil filter is removed carefully inspect the old filter and the filter seating surface on the engine for the gasket from the old filter. Sometimes this will remain in place and is a guaranteed major leak if not removed prior to installing the new filter.
    • Let the rest of the oil from the engine drain and collect in the oil drain pan.
  6. 2005-2007 Ford Focus Oil Change, Preparing and Install the New Oil Filter: Schritt 6, Bild 1 von 2 2005-2007 Ford Focus Oil Change, Preparing and Install the New Oil Filter: Schritt 6, Bild 2 von 2
    • Apply a small amount of clean oil to the rubber gasket on the new oil filter.
    • The use of gloves is highly recommended. If any oil gets on your skin, immediately wash your hands thoroughly.
    • Wipe off the oil filter mounting spot and install the new filter by rotating it clockwise until you cannot tighten it anymore.
  7. 2005-2007 Ford Focus Oil Change, Fill with New Fresh Oil: Schritt 7, Bild 1 von 2 2005-2007 Ford Focus Oil Change, Fill with New Fresh Oil: Schritt 7, Bild 2 von 2
    • Pour five quarts of 5W-20 oil into a funnel in the oil fill hole.
    • Reinstall the oil filler cap by turning it 1/4 turn clockwise.
    • Start your car and let it run. Check for leaking oil underneath the car. If you notice any leaks, tighten the drain plug, being careful not to over-tighten it and crack the oil pan.
    • Close the hood and lower the car back to the ground: you're done!
  8. 2005-2007 Ford Focus Oil Change, Disposal: Schritt 8, Bild 1 von 2 2005-2007 Ford Focus Oil Change, Disposal: Schritt 8, Bild 2 von 2
    • Allow 12-24 hours for all of the oil to drain out of the old oil filter.
    • Take your old oil and filter to a recycling facility. Most auto parts stores and repair shops accept these at no charge to you. In addition, some cities and/or counties have a service where they will collect used oil and filters from your home. For more information, see the American Petroleum Institute's web page on used motor oil collection and recycling.
    • Do not just throw used oil in the garbage. It is a hazardous waste product that needs to be properly disposed.
Ziellinie
37 weitere Nutzer:innen haben diese Anleitung absolviert.
David Hodson
150.493 Reputation
127 Anleitungen geschrieben
14 Kommentare
Excelente aporte David. Muy útil la información para realizarlo de una manera eficiante.
Saludos
JORGE ALVARADO - Antwort
My 07 ford focus ses has just surpassed the 300, 000 klm mark. Only idem I've had to replace is the alternator in the past year.
Car is still running flawlessly. Iam shooting
For 500,000 klms. Think I'll make it?
steveb.2088.sb - Antwort
How’s the car lasting?
BikeHelmet -
How's she running?
I just passed 217000
As rcics -
Thank you, especially for clear instructional photos :)
Anne - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 10
Letzte 7 Tage: 73
Letzte 30 Tage: 392
Insgesamt: 291,303
