Zum Hauptinhalt wechseln
2005 Chrysler Town & Country 3.8L Heater Control Valve Replacement
Was du brauchst
  1. 2005 Chrysler Town & Country 3.8L Heater Control Valve Replacement, Heater Control Valve: Schritt 1, Bild 1 von 3 2005 Chrysler Town & Country 3.8L Heater Control Valve Replacement, Heater Control Valve: Schritt 1, Bild 2 von 3 2005 Chrysler Town & Country 3.8L Heater Control Valve Replacement, Heater Control Valve: Schritt 1, Bild 3 von 3
    • Make sure your vehicle is off and your engine is completely cool before beginning.
    • Unlatch your hood by pulling the lever underneath the steering wheel.
    • Release the latch under the front of the hood.
    • Open the hood and insert the prop rod into the prop rod groove.
  2. 2005 Chrysler Town & Country 3.8L Heater Control Valve Replacement: Schritt 2, Bild 1 von 2 2005 Chrysler Town & Country 3.8L Heater Control Valve Replacement: Schritt 2, Bild 2 von 2
    • Locate the regulator valve under the windshield wiper assembly, just in front of the firewall.
  3. 2005 Chrysler Town & Country 3.8L Heater Control Valve Replacement: Schritt 3, Bild 1 von 3 2005 Chrysler Town & Country 3.8L Heater Control Valve Replacement: Schritt 3, Bild 2 von 3 2005 Chrysler Town & Country 3.8L Heater Control Valve Replacement: Schritt 3, Bild 3 von 3
    • Use pliers to squeeze the clamp tabs on the right side of the valve.
    • While squeezing the clamp tabs, pull the hose to the right to disconnect it from the valve.
  4. 2005 Chrysler Town & Country 3.8L Heater Control Valve Replacement: Schritt 4, Bild 1 von 2 2005 Chrysler Town & Country 3.8L Heater Control Valve Replacement: Schritt 4, Bild 2 von 2
    • Take note of the original orientation of the valve before removal.
    • Use pliers to squeeze the clamp tabs on the left side of the valve.
    • While squeezing the left valve clamp tabs, disconnect the left side of the valve from the hose.
  5. 2005 Chrysler Town & Country 3.8L Heater Control Valve Replacement: Schritt 5, Bild 1 von 1
    • With your replacement valve in your free hand, squeeze the clamp tabs on the left hose and insert the replacement valve into the hose.
    • Make sure the hose is pressed all the way against the valve.
    • If there is an arrow on your new valve, it should point away from the heat intake (the hose going into your vehicle's cabin).
  6. 2005 Chrysler Town & Country 3.8L Heater Control Valve Replacement: Schritt 6, Bild 1 von 1
    • Ensure the clamp is snugly fit around the hose, and securely clamped down on the valve inside the hose, before you release the clamp tabs.
    • Leave about a quarter-inch gap between the clamp and the valve.
  7. 2005 Chrysler Town & Country 3.8L Heater Control Valve Replacement: Schritt 7, Bild 1 von 2 2005 Chrysler Town & Country 3.8L Heater Control Valve Replacement: Schritt 7, Bild 2 von 2
    • While squeezing the clamp tabs on the right hose with pliers, insert the hose into the right side of the valve.
  8. 2005 Chrysler Town & Country 3.8L Heater Control Valve Replacement: Schritt 8, Bild 1 von 1
    • Ensure the clamp is snug and squarely fit over the hose, and clamping down on the valve inside the hose, before you release the tabs.
    • Leave about a quarter inch gap between the clamp and the valve.
  9. 2005 Chrysler Town & Country 3.8L Heater Control Valve Replacement: Schritt 9, Bild 1 von 1
    • Start your vehicle outdoors and let the engine run until it reaches its normal operating temperature.
    • Ensure there are no leaks around the valve.
Abschluss
If there are leaks on the valve, repeat steps 1-9. Make sure the valve is in the correct orientation and the clamps are snug and properly secured. If a problem still occurs, there may be a hose leak in need of diagnosis and repair.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
John Hamer
211 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 22
Letzte 30 Tage: 68
Insgesamt: 3,345
