Zum Hauptinhalt wechseln
Einleitung
An engine air filter is needed to filter the air flowing into the engine.
Ersatzteile
  1. Identify the open hood latch. It is located to the left of your brake pedal. Pull latch toward you. You should hear a click from the front of the car.
    • Identify the open hood latch. It is located to the left of your brake pedal.
    • Pull latch toward you. You should hear a click from the front of the car.
  2. Walk to the front of the car. Slide your hand under the hood, just above the Honda logo. Feel for a small rectangular lever. Pull the lever up, and lift the hood. Be sure to lift the hood all the way up, until the pneumatic braces hold the hood in place.
    • Walk to the front of the car.
    • Slide your hand under the hood, just above the Honda logo. Feel for a small rectangular lever. Pull the lever up, and lift the hood.
    • Be sure to lift the hood all the way up, until the pneumatic braces hold the hood in place.
  3. Laptop-Akkus
    Wenig Aufwand, große Wirkung.
    Jetzt kaufen
    Laptop-Akkus
    Jetzt kaufen
  4. Identify the Air Filter Housing. Located to the right of your engine, this is the black plastic box directly above the battery.
    • Identify the Air Filter Housing. Located to the right of your engine, this is the black plastic box directly above the battery.
  5. Unscrew the four bolts in the corners of the Air Filter Housing. This loosens the top of the housing from the bottom of the housing.
    • Unscrew the four bolts in the corners of the Air Filter Housing. This loosens the top of the housing from the bottom of the housing.
    • The bolts cannot be completely removed.
  6. Next, separate the air filter housing from the bottom of the housing. To do this, with both hands, grab the Air Filter Housing from the exterior and push towards the engine block while pulling up. It is easiest to remove the top of the housing by grabbing below the air filter, and removing the filter with the top of the housing. It is easiest to remove the top of the housing by grabbing below the air filter, and removing the filter with the top of the housing.
    • Next, separate the air filter housing from the bottom of the housing. To do this, with both hands, grab the Air Filter Housing from the exterior and push towards the engine block while pulling up.
    • It is easiest to remove the top of the housing by grabbing below the air filter, and removing the filter with the top of the housing.
  7. Remove the old air filter by gently pulling it from the top of the Air Filter housing. Replace the old air filter with a new one. The blue side should be facing down.
    • Remove the old air filter by gently pulling it from the top of the Air Filter housing.
    • Replace the old air filter with a new one. The blue side should be facing down.
Abschluss
3 weitere Nutzer haben diese Anleitung absolviert.
Matt Ondriezek
462 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 12-35, Maness Spring 2014 Mitglied von Cal Poly, Team 12-35, Maness Spring 2014
CPSU-MANESS-S14S12G35
4 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 4
Letzte 7 Tage: 16
Letzte 30 Tage: 72
Insgesamt: 2,744
