Zum Hauptinhalt wechseln
2005 Honda Accord Headlight Replacement
Was du brauchst
  1. 2005 Honda Accord Headlight Replacement, Headlight Bulb: Schritt 1, Bild 1 von 1
    • Pop open the hood of the vehicle.
  2. 2005 Honda Accord Headlight Replacement: Schritt 2, Bild 1 von 3 2005 Honda Accord Headlight Replacement: Schritt 2, Bild 2 von 3 2005 Honda Accord Headlight Replacement: Schritt 2, Bild 3 von 3
    • Remove the headlight connector by depressing the clip and pulling it away from the vehicle.
  3. 2005 Honda Accord Headlight Replacement: Schritt 3, Bild 1 von 2 2005 Honda Accord Headlight Replacement: Schritt 3, Bild 2 von 2
    • Turn the headlight counter clockwise to release it from the headlight assembly.
  4. 2005 Honda Accord Headlight Replacement: Schritt 4, Bild 1 von 2 2005 Honda Accord Headlight Replacement: Schritt 4, Bild 2 von 2
    • Pull the headlight bulb out of the socket.
  5. 2005 Honda Accord Headlight Replacement: Schritt 5, Bild 1 von 2 2005 Honda Accord Headlight Replacement: Schritt 5, Bild 2 von 2
    • Inspect your old headlight bulb and compare with new one to ensure it is the same.
  6. 2005 Honda Accord Headlight Replacement: Schritt 6, Bild 1 von 1
    • Align notches and insert the headlight bulb into the socket.
  7. 2005 Honda Accord Headlight Replacement: Schritt 7, Bild 1 von 1
    • Turn it clockwise until the headlight clips in.
  8. 2005 Honda Accord Headlight Replacement: Schritt 8, Bild 1 von 1
    • Reconnect the headlight pigtail.
    • You will hear a click when the connector is fully seated.
  9. 2005 Honda Accord Headlight Replacement: Schritt 9, Bild 1 von 3 2005 Honda Accord Headlight Replacement: Schritt 9, Bild 2 von 3 2005 Honda Accord Headlight Replacement: Schritt 9, Bild 3 von 3
    • Turn on the vehicle to make sure the headlight lights up.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Diego Avila
180 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 11-69, Grodsky Fall 2021 Mitglied von CSU Los Angeles, Team 11-69, Grodsky Fall 2021
CSULA-GRODSKY-F21S11G69
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 68
Insgesamt: 2,009
