Zum Hauptinhalt wechseln
2005 Honda CR-V Car Visor Replacement
Was du brauchst
  1. 2005 Honda CR-V Car Visor Replacement, Car Visor: Schritt 1, Bild 1 von 2 2005 Honda CR-V Car Visor Replacement, Car Visor: Schritt 1, Bild 2 von 2
    • Ensure that the car is parked and utilize the parking brake.
    • Press the switch on the left of the parking lever, pull it outwards, and release it when it is fixed and outward.
  2. 2005 Honda CR-V Car Visor Replacement: Schritt 2, Bild 1 von 2 2005 Honda CR-V Car Visor Replacement: Schritt 2, Bild 2 von 2
    • Remove the outer shell with a spudger.
    • When the outer shell is loose enough, remove it with your hand.
  3. 2005 Honda CR-V Car Visor Replacement: Schritt 3, Bild 1 von 3 2005 Honda CR-V Car Visor Replacement: Schritt 3, Bild 2 von 3 2005 Honda CR-V Car Visor Replacement: Schritt 3, Bild 3 von 3
    • Remove the two 4.5 mm screws from the visor with a Torx screwdriver.
    • After removing the inner layer, the sun visor is now released.
  4. 2005 Honda CR-V Car Visor Replacement: Schritt 4, Bild 1 von 2 2005 Honda CR-V Car Visor Replacement: Schritt 4, Bild 2 von 2
    • Put the 4.5 mm screw removed in the previous step in the new sun visor.
    • Tighten the screw using a Torx screwdriver.
    • Also, note that the shape of the shell is aligned with the form of the hole in the roof.
  5. 2005 Honda CR-V Car Visor Replacement: Schritt 5, Bild 1 von 2 2005 Honda CR-V Car Visor Replacement: Schritt 5, Bild 2 von 2
    • Screw in the rest of the 4.5 mm screws back in the sun visor using a Torx screwdriver.
    • Ensure that the screws are tight.
  6. 2005 Honda CR-V Car Visor Replacement: Schritt 6, Bild 1 von 3 2005 Honda CR-V Car Visor Replacement: Schritt 6, Bild 2 von 3 2005 Honda CR-V Car Visor Replacement: Schritt 6, Bild 3 von 3
    • Put the outer shell back on top of the inner shell.
    • Finally, ensure that the sun visor can be moved to the driver-side window and twisted upwards and downwards.
Abschluss
To replace the new sun visor with the old sun visor, follow these steps in the same order.
An Chen
133 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 2-24, Briggs Spring 2023 Mitglied von CSU Los Angeles, Team 2-24, Briggs Spring 2023
CSULA-BRIGGS-S23S2G24
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 40
Insgesamt: 443
