Zum Hauptinhalt wechseln
2005 Infiniti G35 Windshield Wiper Replacement
  1. 2005 Infiniti G35 Windshield Wiper Replacement, Windshield Wiper: Schritt 1, Bild 1 von 2 2005 Infiniti G35 Windshield Wiper Replacement, Windshield Wiper: Schritt 1, Bild 2 von 2
    • Lift up on the drivers side windshield wiper.
    • The wiper blade should stay in its upright position while you work.
  2. 2005 Infiniti G35 Windshield Wiper Replacement: Schritt 2, Bild 1 von 2 2005 Infiniti G35 Windshield Wiper Replacement: Schritt 2, Bild 2 von 2
    • Rotate the wiper blade 180 degrees so that it is parallel with the windshield.
  3. 2005 Infiniti G35 Windshield Wiper Replacement: Schritt 3, Bild 1 von 2 2005 Infiniti G35 Windshield Wiper Replacement: Schritt 3, Bild 2 von 2
    • Push down on the middle of the wiper blade until you hear/feel a click.
  4. 2005 Infiniti G35 Windshield Wiper Replacement: Schritt 4, Bild 1 von 3 2005 Infiniti G35 Windshield Wiper Replacement: Schritt 4, Bild 2 von 3 2005 Infiniti G35 Windshield Wiper Replacement: Schritt 4, Bild 3 von 3
    • Rotate the wiper blade back to its original position.
    • Pull down on the blade until it detaches from the wiper arm.
  5. 2005 Infiniti G35 Windshield Wiper Replacement: Schritt 5, Bild 1 von 3 2005 Infiniti G35 Windshield Wiper Replacement: Schritt 5, Bild 2 von 3 2005 Infiniti G35 Windshield Wiper Replacement: Schritt 5, Bild 3 von 3
    • Slide the new wiper blade onto the wiper arm in the same position that you removed the old blade.
    • Slide with moderate pressure until you hear a click.
  6. 2005 Infiniti G35 Windshield Wiper Replacement: Schritt 6, Bild 1 von 2 2005 Infiniti G35 Windshield Wiper Replacement: Schritt 6, Bild 2 von 2
    • Hold the wiper blade against the arm to gently lay the arm down without damaging the new wiper blade.
  7. 2005 Infiniti G35 Windshield Wiper Replacement: Schritt 7, Bild 1 von 1
    • Repeat steps 1-6 for the passenger side windshield wiper.
Abschluss
Solomon Vlasak
150 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 13
Insgesamt: 513
