Einleitung
If the wiper blades on your 2005 Infiniti G35 start to lose their water and snow wiping capabilities then it might be time to replace them.
The wiper blades on your vehicle are an extremely important piece of safety equipment used to maintain visibility. For this reason use this guide to replace your wiper blades, so that they function properly. For this guide it is important that you use the correct size of wiper blade, the drivers side blade is 22” and the passengers side blade is 17”.
Choosing the right wiper blade is also very important, if you get a bad product it could lead to premature wear and failure. In order to help with this I found a very informative and non-biased video to help you in choosing the correct wiper blade.
Rotate the wiper blade back to its original position.
Pull down on the blade until it detaches from the wiper arm.
Slide the new wiper blade onto the wiper arm in the same position that you removed the old blade.
Hold the wiper blade against the arm to gently lay the arm down without damaging the new wiper blade.
