Zum Hauptinhalt wechseln
2005 Jeep Liberty Fog Light Replacement
Was du brauchst
  1. 2005 Jeep Liberty Fog Light Replacement, Fog Light: Schritt 1, Bild 1 von 1
    • Open the hood to access the radiator grill tabs.
    • Pull up on the first tab and repeat for the remaining four tabs.
  2. 2005 Jeep Liberty Fog Light Replacement: Schritt 2, Bild 1 von 1
    • Tilt the radiator grill cover forward and lift up and out to remove.
  3. 2005 Jeep Liberty Fog Light Replacement: Schritt 3, Bild 1 von 1
    • Using an allen wrench, turn the tension screw counter-clockwise to loosen the light housing.
  4. 2005 Jeep Liberty Fog Light Replacement: Schritt 4, Bild 1 von 1
    • Lift up on the tension screw to release the light housing.
  5. 2005 Jeep Liberty Fog Light Replacement: Schritt 5, Bild 1 von 1
    • Using a flat-head screwdriver, pull the tab outward to remove the light housing.
    • Repeat the procedure for the right side of the light housing.
  6. 2005 Jeep Liberty Fog Light Replacement: Schritt 6, Bild 1 von 1
    • Pull the light housing toward you.
  7. 2005 Jeep Liberty Fog Light Replacement: Schritt 7, Bild 1 von 1
    • Remove the wiring harness from the light socket by lifting up on the tab with a flat-head screwdriver.
  8. 2005 Jeep Liberty Fog Light Replacement: Schritt 8, Bild 1 von 1
    • Remove the light socket from the light housing by turning counter-clockwise.
  9. 2005 Jeep Liberty Fog Light Replacement: Schritt 9, Bild 1 von 1
    • Remove the light socket from the light housing and replace.
    • The light socket part number is 9145 and can be purchased at any auto parts store.
    • Install the new light socket back into the light housing by turning clockwise.
    • Plug the wiring harness back in the light socket.
Abschluss
Test the replacement light socket by turning the lights on. If working, reinstall the light housing and radiator grill cover.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Pasco Hernando, Team S4-G55, Prince Winter 2017 Mitglied von Pasco Hernando, Team S4-G55, Prince Winter 2017
PHSC-PRINCE-W17S4G55
1 Mitglied
1 Anleitung geschrieben
2 Kommentare
Thank you for your information, if you are looking for a place that sells the best and most trusted car fog lamps. Check this out!
vievie aryanti - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 11
Letzte 30 Tage: 26
Insgesamt: 7,242
