Zum Hauptinhalt wechseln
2005 Mustang GT Serpentine Belt Tensioner Replacement
Was du brauchst
  1. 2005 Mustang GT Serpentine Belt Tensioner Replacement, Serpentine Belt Tensioner: Schritt 1, Bild 1 von 1
    • To open the hood, pull the hood latch located on the left side of the driver's foot well.
  2. 2005 Mustang GT Serpentine Belt Tensioner Replacement: Schritt 2, Bild 1 von 3 2005 Mustang GT Serpentine Belt Tensioner Replacement: Schritt 2, Bild 2 von 3 2005 Mustang GT Serpentine Belt Tensioner Replacement: Schritt 2, Bild 3 von 3
    • Push a lever (located just above the horse in the grill) to the left.
    • Lift the hood up, pull the prop out, and insert it into the hole on the hood labeled "prop."
  3. 2005 Mustang GT Serpentine Belt Tensioner Replacement: Schritt 3, Bild 1 von 2 2005 Mustang GT Serpentine Belt Tensioner Replacement: Schritt 3, Bild 2 von 2
    • Disconnect the battery using an 8 mm socket and 3/8 inch drive ratchet.
  4. 2005 Mustang GT Serpentine Belt Tensioner Replacement: Schritt 4, Bild 1 von 1
    • Loosen the band clamp on the throttle body with a flathead screwdriver.
  5. 2005 Mustang GT Serpentine Belt Tensioner Replacement: Schritt 5, Bild 1 von 1
    • Loosen the band clamp on the air filter or airbox.
  6. 2005 Mustang GT Serpentine Belt Tensioner Replacement: Schritt 6, Bild 1 von 3 2005 Mustang GT Serpentine Belt Tensioner Replacement: Schritt 6, Bild 2 von 3 2005 Mustang GT Serpentine Belt Tensioner Replacement: Schritt 6, Bild 3 von 3
    • Pull the intake tube back and to the left to remove it from the throttle body and airbox.
    • Place the intake tube out of the way
  7. 2005 Mustang GT Serpentine Belt Tensioner Replacement: Schritt 7, Bild 1 von 1
    • Make note of the orientation that the serpentine belt runs. If the tensioner is broken, and the belt is no longer on, refer to a diagram for the vehicle. If still attached, release tension on the belt using a 1/2 inch breaker bar turned in the clockwise direction and remove it.
  8. 2005 Mustang GT Serpentine Belt Tensioner Replacement: Schritt 8, Bild 1 von 1
    • Remove the three 10 mm bolts with your 3/8 drive and 10 mm socket.
    • Remove the tensioner.
  9. 2005 Mustang GT Serpentine Belt Tensioner Replacement: Schritt 9, Bild 1 von 1
    • Install the new tensioner and torque the bolts to 20ft lbs. then using the breaker bar turn clockwise to allow the reinstallation of the belt.
    • Using the breaker bar, turn clockwise to allow the reinstallation of the belt.
  10. 2005 Mustang GT Serpentine Belt Tensioner Replacement: Schritt 10, Bild 1 von 1
    • Make sure all the grooves of the pullies are seated in the belt correctly, then release the tensioner to seat the belt.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Patrick Hall
202 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S1-G9, Sinclaire Spring 2021 Mitglied von UMass Dartmouth, Team S1-G9, Sinclaire Spring 2021
UMASSD-SINCLAIRE-S21S1G9
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 56
Insgesamt: 2,307
