Einleitung
Low-beam headlights help you see the road clearly at night or in bad weather without blinding other drivers, ensuring safe and comfortable driving.
Driving with burnt low-beam headlight bulbs will result in traffic stops and also lead to a higher risk of an accident occurring.
This guide will go over the steps needed to replace the low-beam headlight bulb in a 2006–2013 Lexus IS250.
Before you begin, turn off the car, put it in park, and engage the emergency brake.
Was du brauchst
Pull the hood release in the lower left of the driver's side of your car.
Lift the hood of your car until it stays up on its own.
Use any size flathead screwdriver to remove the screw plugs that are holding down the engine cover.
Use a 1/4" flathead screwdriver to remove the screw holding down the top engine cover.
Push the metal clips inward to release the headlight bulb.
Pull the bull out of the socket.
