Einleitung
This guide demonstrates how to replace a halogen low-beam headlight bulb in a 2006-2011 Honda Civic Coupe. You will need a Sylvania SilverStar 9006 ST ZXE halogen headlight bulb, or two if you need to replace both lightbulbs.
Keep in mind that, when handling a halogen lightbulb, you should avoid touching the glass part of the bulb with your hands; The oils can reduce the life of the bulb. It is recommended that you do this replacement on a sunny day to help you see, or have someone hold a flashlight for you if needed.
Prior to starting this repair, turn off your car , make sure it is cool. and put on your emergency break for safety.
Was du brauchst
Pull the hood release lever underneath the driver wheel near the lower door hinge to unlock the hood.
Find the hood-release latch underneath the hood, just above the Honda logo on the grill of your vehicle.
Once you feel this latch, press it upward to fully release the hood and lift it up.
After lifting the hood, take the hood support rod that is lying across the front of the car and insert the free end of the rod into the support rod hole found in the hood.
Turn on the car and with the steering wheel, turn the tires to access the lightbulb.
Sit next to your tire and look under the body toward the front of the car.
Identify the headlight by looking for a clip connected to a wire such as the white one shown.
Press firmly on the bottom of the center cut-out portion of the clip. This will unlatch the clip from the bulb.
As you push down on the clip to release it, pull the clip off.
Grab the back of the bulb and rotate it counter-clockwise to the "off" position.
Pull the bulb toward you to remove it.
Grab your replacement bulb.
Insert your new bulb in reverse-order as you did removing it: Place it into the hole in the "off" position, and rotate it clockwise to the "on" position.
Tug on the back of the bulb to ensure that it has been properly secured.
Reattach the electrical wiring clip by sliding it back onto the rear side of the bulb.
Detach the hood support rod and close the hood of your car.
Turn on your headlights to make sure the new bulb has been properly connected. The bulb in the center of the headlight should be thoroughly lit.
If you would like, turn your car on again to re-adjust your tires back to their normal position. Now, you're done!
These instructions can be followed for replacing both the passenger-side bulb and the driver-side bulb.
5 weitere Personen haben diese Anleitung absolviert.
