Einleitung
A loose or hanging sun visor is a driving hazard to the driver, other people in the car, and other motorists. The visor can drop suddenly causing you to wreck your car. Fortunately, there are plenty of new and used sun visors to choose from. Just google your car’s make and model and start shopping.
This guide has easy step-by-step instructions to replace that visor and make your car safe to drive. You will need a T15 Torx screwdriver.
Was du brauchst
Reconnect the new sun visor wire.
Pull down slightly on the headliner and tuck the wire back inside.
The same steps apply to replace the passenger side sun visor.
