Einleitung
If the blinker bulb on your Dodge Ram 2006 is not flashing, it may be due to a burnt bulb. Use this guide to help replace a burnt bulb. In step two, when you pull the light casing out, wires will be attached to the case. Please do not touch the wires as they are exposed electrical wires and may cause harm to you or the cables themselves.
Was du brauchst
Remove the two screws securing the light to the truck using an Allen wrench.
Replace the light bulb by gently pulling the original light bulb out.
Replace the lightbulb with a new one.
Reattach the lightbulbs to the light casing and put the 4 screws back in.
Pop the light casing back into place by making sure the two pointed ends go into the holes.
Replace the two screws that secure the light to the truck using an Allen wrench.
