Zum Hauptinhalt wechseln
2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement
Was du brauchst
  1. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement, Throttle Position Sensor (TPS): Schritt 1, Bild 1 von 2 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement, Throttle Position Sensor (TPS): Schritt 1, Bild 2 von 2
    • Pull the release lever for the hood.
  2. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: Schritt 2, Bild 1 von 1
    • Slide the latch under the center of the hood to the left and then open the hood.
  3. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: Schritt 3, Bild 1 von 1
    • Disconnect the positive battery terminal by loosening the 10 mm nut and pulling the wire of the red battery terminal.
  4. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: Schritt 4, Bild 1 von 3 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: Schritt 4, Bild 2 von 3 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: Schritt 4, Bild 3 von 3
    • Remove the connector attached to the TPS by sliding back the red clip and pulling.
  5. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: Schritt 5, Bild 1 von 1
    • Use a T20 Torx screwdriver to remove the two bolts holding in the sensor.
  6. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: Schritt 6, Bild 1 von 2 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: Schritt 6, Bild 2 von 2
    • Remove the old TPS.
  7. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: Schritt 7, Bild 1 von 1
    • Install the new TPS and put the two T20 Torx bolts back in.
  8. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: Schritt 8, Bild 1 von 1
    • Connect the connector to the new TPS and make sure the red clip is pushed forward.
  9. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: Schritt 9, Bild 1 von 1
    • Reconnect the positive battery terminal, by tightening the 10 mm nut and putting the red cover back over it.
  10. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: Schritt 10, Bild 1 von 1
    • Close the hood and make sure it is closed securely.
  11. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: Schritt 11, Bild 1 von 1
    • Start the car and make sure that it is running normally.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 17
Letzte 30 Tage: 68
Insgesamt: 3,215
