Zum Hauptinhalt wechseln
2006 Honda Shadow Spirit 750 Battery Replacement
Was du brauchst
  1. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove outer casing: Schritt 1, Bild 1 von 1
    • Remove the plastic covering, located on the left side of the bike, by pulling the piece straight off the bike.
  2. 2006 Honda Shadow Spirit 750 Battery Replacement, Open toolbox: Schritt 2, Bild 1 von 3 2006 Honda Shadow Spirit 750 Battery Replacement, Open toolbox: Schritt 2, Bild 2 von 3 2006 Honda Shadow Spirit 750 Battery Replacement, Open toolbox: Schritt 2, Bild 3 von 3
    • The tool box is located under the panel.
    • Using the key to the motorbike, unlock the tool box.
    • Remove the plastic bag inside holding the tools needed for basic maintenance for the motorbike.
  3. 2006 Honda Shadow Spirit 750 Battery Replacement, Unscrew the seat: Schritt 3, Bild 1 von 2 2006 Honda Shadow Spirit 750 Battery Replacement, Unscrew the seat: Schritt 3, Bild 2 von 2
    • Using the allen wrench, remove the screws on both sides of the bike seat.
  4. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove the seat: Schritt 4, Bild 1 von 1
    • Pull the rear of the seat upwards.
    • Pull the seat backwards to remove it from the bike.
  5. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove plastic covering: Schritt 5, Bild 1 von 1
    • Using the screwdriver, remove the screw holding the plastic cover.
  6. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove the fusebox: Schritt 6, Bild 1 von 1
    • Pull the cover off the battery and remove the fuse box from the cover.
    • Place the fuse box over to the side right of the bike. Do not disconnect the wires.
  7. 2006 Honda Shadow Spirit 750 Battery Replacement, Detach the ground wire: Schritt 7, Bild 1 von 1
    • Using the screwdriver, remove the ground wire (negative (-) cable) from the battery.
    • Place the wire over the left side of the bike.
  8. 2006 Honda Shadow Spirit 750 Battery Replacement, Detach the power cable: Schritt 8, Bild 1 von 1
    • Also using the screwdriver, remove the positive (+) cable from the battery.
    • Place the wire over the right side of the bike.
    • Do not let the red(+) and black(-) wires touch
  9. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove the battery: Schritt 9, Bild 1 von 1
    • Remove the battery from the bike by pulling upwards.
Abschluss
9 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 1-7, Donnelly Fall 2014 Mitglied von USF Tampa, Team 1-7, Donnelly Fall 2014
USFT-DONNELLY-F14S1G7
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 19
Letzte 30 Tage: 74
Insgesamt: 18,761
