Einleitung
This replacement involves removing the crank arm in order to access the chainring you are trying to replace.
Was du brauchst
Screw the larger diameter threads on the crank puller into the hole you removed the cap from.
Slightly tighten it with an adjustable wrench.
Tighten the handle on the crank puller until the arm and gears slide off of the axle.
Remove the four 6mm hex bolts from the small chainring using the 6mm hex screwdriver. This will allow you to remove the chainring.
