Zum Hauptinhalt wechseln
2006 Iron Horse Warrior Rear Wheel Replacement
  1. 2006 Iron Horse Warrior Rear Wheel Replacement, Rear Wheel: Schritt 1, Bild 1 von 2 2006 Iron Horse Warrior Rear Wheel Replacement, Rear Wheel: Schritt 1, Bild 2 von 2
    • Turn the bike upside down if you don't have a bike stand. This will make it easier to remove the tire.
    • Unfasten the left side of the wheel by pulling the black "L" shaped lever up with your hands.
    Frag FixBot
    Kommentar hinzufügen
  2. 2006 Iron Horse Warrior Rear Wheel Replacement: Schritt 2, Bild 1 von 2 2006 Iron Horse Warrior Rear Wheel Replacement: Schritt 2, Bild 2 von 2
    • On the right side, use your hands to unscrew the cap of the axle counterclockwise until it is loose.
    Frag FixBot
  3. 2006 Iron Horse Warrior Rear Wheel Replacement: Schritt 3, Bild 1 von 2 2006 Iron Horse Warrior Rear Wheel Replacement: Schritt 3, Bild 2 von 2
    • Push down on the the tire with your hands to remove it from the frame of the bike.
    • Sometimes the axle will get caught in the boxed area. Use both of your hands to cautiously push it down harder until the tire comes loose. This may require a fair amount of force.
    Frag FixBot
Abschluss
Cal Poly, Team 15-2, Amido Spring 2015 Mitglied von Cal Poly, Team 15-2, Amido Spring 2015
CPSU-AMIDO-S15S15G2
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 12
Letzte 30 Tage: 44
Insgesamt: 1,518
