Zum Hauptinhalt wechseln
2006 Iron Horse Warrior Tire/Tube Replacement
Was du brauchst
  1. 2006 Iron Horse Warrior Tire/Tube Replacement, Rear Wheel: Schritt 1, Bild 1 von 2 2006 Iron Horse Warrior Tire/Tube Replacement, Rear Wheel: Schritt 1, Bild 2 von 2
    • Turn the bike upside down if you don't have a bike stand. This will make it easier to remove the tire.
    • Unfasten the left side of the wheel by pulling the black "L" shaped lever up with your hands.
    Frag FixBot
    Kommentar hinzufügen
  2. 2006 Iron Horse Warrior Tire/Tube Replacement: Schritt 2, Bild 1 von 2 2006 Iron Horse Warrior Tire/Tube Replacement: Schritt 2, Bild 2 von 2
    • On the right side, use your hands to unscrew the cap of the axle counterclockwise until it is loose.
    Frag FixBot
  3. 2006 Iron Horse Warrior Tire/Tube Replacement: Schritt 3, Bild 1 von 2 2006 Iron Horse Warrior Tire/Tube Replacement: Schritt 3, Bild 2 von 2
    • Push down on the the tire with your hands to remove it from the frame of the bike.
    • Sometimes the axle will get caught in the boxed area. Use both of your hands to cautiously push it down harder until the tire comes loose. This may require a fair amount of force.
    Frag FixBot
  4. 2006 Iron Horse Warrior Tire/Tube Replacement, Tire/Tube: Schritt 4, Bild 1 von 3 2006 Iron Horse Warrior Tire/Tube Replacement, Tire/Tube: Schritt 4, Bild 2 von 3 2006 Iron Horse Warrior Tire/Tube Replacement, Tire/Tube: Schritt 4, Bild 3 von 3
    • Slightly loosen the valve bolt counterclockwise with your thumb and index finger.
    • Deflate the tire by pressing down the air valve tip with your finger. Use as much pressure as needed to hear the air flowing out of the tube.
    Frag FixBot
  5. 2006 Iron Horse Warrior Tire/Tube Replacement: Schritt 5, Bild 1 von 3 2006 Iron Horse Warrior Tire/Tube Replacement: Schritt 5, Bild 2 von 3 2006 Iron Horse Warrior Tire/Tube Replacement: Schritt 5, Bild 3 von 3
    • Use you thumb and index finger to unscrew the valve nut by rotating it counterclockwise.
    Frag FixBot
  6. 2006 Iron Horse Warrior Tire/Tube Replacement: Schritt 6, Bild 1 von 3 2006 Iron Horse Warrior Tire/Tube Replacement: Schritt 6, Bild 2 von 3 2006 Iron Horse Warrior Tire/Tube Replacement: Schritt 6, Bild 3 von 3
    • Hold the tire lever firmly in your hands and look for the boundary between the tire and the wheel rim. Apply great force to the lever until you pry the rim and the tire apart.
    • You can do this step anywhere along the circumference of the wheel.
    • With the tip of the lever inserted between the rim and the tire, rotate the lever 90° counterclockwise and fix the lever to the metal spokes using the arrow shaped slot located on the top of the lever.
    Frag FixBot
  7. 2006 Iron Horse Warrior Tire/Tube Replacement: Schritt 7, Bild 1 von 2 2006 Iron Horse Warrior Tire/Tube Replacement: Schritt 7, Bild 2 von 2
    • Insert an extra tire lever between the tire and the rim.
    • Move the lever along the circumference of the rim to pry the tire apart.
    • You may attach as many tire levers on the spokes as you feel necessary to make this step easier.
    Frag FixBot
  8. 2006 Iron Horse Warrior Tire/Tube Replacement: Schritt 8, Bild 1 von 3 2006 Iron Horse Warrior Tire/Tube Replacement: Schritt 8, Bild 2 von 3 2006 Iron Horse Warrior Tire/Tube Replacement: Schritt 8, Bild 3 von 3
    • Start removing the tire by unplugging the valve from the rim slot.
    • Remove the rest of the tire and the tube from the rim.
    Frag FixBot
Abschluss
Once you have completed this guide, assemble the wheel back on the bike.
Cal Poly, Team 15-2, Amido Spring 2015 Mitglied von Cal Poly, Team 15-2, Amido Spring 2015
CPSU-AMIDO-S15S15G2
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 41
Insgesamt: 2,962
