Zum Hauptinhalt wechseln
2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement
Was du brauchst
  1. 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement, Front Brake Master Cylinder: Schritt 1, Bild 1 von 3 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement, Front Brake Master Cylinder: Schritt 1, Bild 2 von 3 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement, Front Brake Master Cylinder: Schritt 1, Bild 3 von 3
    • Turn the bike off and allow it to fully cool. Put nitrile gloves on before beginning.
    • Use a 3/32 inch Allen key to remove the bolt securing the brake lever.
  2. 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: Schritt 2, Bild 1 von 3 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: Schritt 2, Bild 2 von 3 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: Schritt 2, Bild 3 von 3
    • Place a rag directly under the hose connection to catch any break fluid spills.
    • Use pliers to remove the clamp at the end of the reservoir hose.
    • Empty the brake fluid into an empty container.
  3. 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: Schritt 3, Bild 1 von 3 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: Schritt 3, Bild 2 von 3 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: Schritt 3, Bild 3 von 3
    • Use an 8 mm socket attached to a 3/8 inch ratchet to remove the two bolts.
  4. 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: Schritt 4, Bild 1 von 3 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: Schritt 4, Bild 2 von 3 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: Schritt 4, Bild 3 von 3
    • Grip the boot with your pliers and pull it out of its housing.
    • Use snap ring pliers to remove the snap ring behind the boot.
  5. 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: Schritt 5, Bild 1 von 1
    • Use pliers to pull out the spring and piston assembly.
  6. 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: Schritt 6, Bild 1 von 1
    • Check the condition of the master cylinder, and clean the cylinder with brake cleaner. Dry it with a rag.
    • If your master cylinder is corroded or in poor shape, you will need to buy a new or used master cylinder assembly and replace it.
  7. 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: Schritt 7, Bild 1 von 1
    • Fit the new seals onto the piston.
    • Use a bit of new brake fluid as lubrication.
  8. 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: Schritt 8, Bild 1 von 1
    • Place the new spring and piston back into the cylinder.
  9. 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: Schritt 9, Bild 1 von 1
    • While holding the piston and spring down, use snap ring pliers to place the snap ring in the same orientation that it was taken out.
    • Use pliers to push the assembly together.
  10. 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: Schritt 10, Bild 1 von 1
    • Replace the rubber boot.
  11. 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: Schritt 11, Bild 1 von 3 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: Schritt 11, Bild 2 von 3 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: Schritt 11, Bild 3 von 3
    • Use an 8 mm socket attached to a 3/8 inch ratchet to secure the two bolts.
    • Use pliers to pinch the clamp until it is in the right position like the photo.
    • Replace your brake lever, then tighten the single bolt using a 3/32 inch Allen key.
  12. 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: Schritt 12, Bild 1 von 3 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: Schritt 12, Bild 2 von 3 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: Schritt 12, Bild 3 von 3
    • Remember to bleed the system while adding new fluid!
    • Refill the brake fluid reservoir to the appropriate level with new brake fluid.
    • Perform a quick test by pulling the brake lever and check that the front brake is functioning properly.
    • Congratulations! You are all done and ready to ride!
Abschluss
Your front brake is now working as intended!
prabhmeet sidhu
205 Reputation
1 Anleitung geschrieben
York University, Team P-28, O'Regan Winter 2022 Mitglied von York University, Team P-28, O'Regan Winter 2022
YORK-O'REGAN-W22SPG28
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 31
Insgesamt: 818
