Zum Hauptinhalt wechseln
2006 Toyota Tacoma Signal Lights Replacement
Was du brauchst
  1. 2006 Toyota Tacoma Signal Lights Replacement, Signal Lights: Schritt 1, Bild 1 von 2 2006 Toyota Tacoma Signal Lights Replacement, Signal Lights: Schritt 1, Bild 2 von 2
    • Turn on the car, and switch the signal light ignition, so that both lights turn on.
  2. 2006 Toyota Tacoma Signal Lights Replacement: Schritt 2, Bild 1 von 3 2006 Toyota Tacoma Signal Lights Replacement: Schritt 2, Bild 2 von 3 2006 Toyota Tacoma Signal Lights Replacement: Schritt 2, Bild 3 von 3
    • Turn on your car, and check the signal lights on the rear end of the car.
    • Identify which side stopped blinking and/or burnt out (left side or right side).
  3. 2006 Toyota Tacoma Signal Lights Replacement: Schritt 3, Bild 1 von 2 2006 Toyota Tacoma Signal Lights Replacement: Schritt 3, Bild 2 von 2
    • Find a new replacement signal bulb according to the side where the light needs to be replaced.
    • Use the car model, make and year to find the light that best suits the car.
  4. 2006 Toyota Tacoma Signal Lights Replacement: Schritt 4, Bild 1 von 1
    • Prepare to remove the old turn signal.
    • Open the hood of the lens.
  5. 2006 Toyota Tacoma Signal Lights Replacement: Schritt 5, Bild 1 von 2 2006 Toyota Tacoma Signal Lights Replacement: Schritt 5, Bild 2 von 2
    • If needed, use a screwdriver to remove hood.
  6. 2006 Toyota Tacoma Signal Lights Replacement: Schritt 6, Bild 1 von 3 2006 Toyota Tacoma Signal Lights Replacement: Schritt 6, Bild 2 von 3 2006 Toyota Tacoma Signal Lights Replacement: Schritt 6, Bild 3 von 3
    • Remove the light bulb casing.
  7. 2006 Toyota Tacoma Signal Lights Replacement: Schritt 7, Bild 1 von 3 2006 Toyota Tacoma Signal Lights Replacement: Schritt 7, Bild 2 von 3 2006 Toyota Tacoma Signal Lights Replacement: Schritt 7, Bild 3 von 3
    • If needed, replace the electric connector with a new one, aligning and screwing the replacement in the same place.
    • Push the locking and turn it counterclockwise to unscrew the bulb.
  8. 2006 Toyota Tacoma Signal Lights Replacement: Schritt 8, Bild 1 von 2 2006 Toyota Tacoma Signal Lights Replacement: Schritt 8, Bild 2 von 2
    • Replace the bulb with the new one.
    • Insert the new bulb. Align the pins on the bulb with the ones inside of the car.
  9. 2006 Toyota Tacoma Signal Lights Replacement: Schritt 9, Bild 1 von 3 2006 Toyota Tacoma Signal Lights Replacement: Schritt 9, Bild 2 von 3 2006 Toyota Tacoma Signal Lights Replacement: Schritt 9, Bild 3 von 3
    • Place the new bulb back on the designated place.
    • Replace the hood/lens back on the car.
    • Turn the ignition switch on and engage the blinker lever (first step) to ensure proper instalment.
Abschluss
Sofía Galán
181 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 25
Insgesamt: 584
