Einleitung
If your turn signal lights aren't responding when you use the turn signal ignition, it may be a sign that you need to replace the light bulb for your signal lights. Signal lights are an important feature of cars, as they provide security for the driver and others around them. While they are proven to last long, it can be expensive to replace if done by a professional.
In this guide, you will find a step by step guide detailing the process of repairing and/or changing signal lights in the 2006 Toyota Tacoma, requiring little to no experience on the subject.
Was du brauchst
Turn on the car, and switch the signal light ignition, so that both lights turn on.
Turn on your car, and check the signal lights on the rear end of the car.
Identify which side stopped blinking and/or burnt out (left side or right side).
Find a new replacement signal bulb according to the side where the light needs to be replaced.
Replace the bulb with the new one.
Insert the new bulb. Align the pins on the bulb with the ones inside of the car.
Place the new bulb back on the designated place.
Replace the hood/lens back on the car.
