Zum Hauptinhalt wechseln
2007-2012 Acura RDX Engine Air Filter Replacement
Was du brauchst
  1. 2007-2012 Acura RDX Engine Air Filter Replacement, Engine Air Filter: Schritt 1, Bild 1 von 1
    • On the driver-side footwell, pull the latch to open the hood.
    • Make sure you leave time between driving and performing this fix. Working around the engine while it is still hot presents a burn risk!
  2. 2007-2012 Acura RDX Engine Air Filter Replacement: Schritt 2, Bild 1 von 1
    • Lift up the second latch to fully open the hood.
    • This one is located right above the Acura logo on the front of the car.
  3. 2007-2012 Acura RDX Engine Air Filter Replacement: Schritt 3, Bild 1 von 1
    • The airbox is directly behind the battery. Remove the four 9 mm bolts holding the airbox down.
    • If you ever had the bolts replaced, they may have a slightly different head diameter. If a 9 mm socket doesn't fit, use the appropriate size socket.
  4. 2007-2012 Acura RDX Engine Air Filter Replacement: Schritt 4, Bild 1 von 1
    • Unscrew each of the bolts. Do not remove the bolts.
    • If the bolts are stuck, use some WD-40 or similar lubricant to help loosen them.
  5. 2007-2012 Acura RDX Engine Air Filter Replacement: Schritt 5, Bild 1 von 2 2007-2012 Acura RDX Engine Air Filter Replacement: Schritt 5, Bild 2 von 2
    • Remove the air filter from the vehicle.
    • In many cases, air filters will have an arrow to show the direction they should go. This direction represents the airflow, for this particular car we want that facing upwards.
    • Do not fully remove the bolts.
Abschluss
One the task is done, close the hood and you are good to drive!
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Andrew Graham
145 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S2-G6, Riel Spring 2021 Mitglied von UMass Dartmouth, Team S2-G6, Riel Spring 2021
UMASSD-RIEL-S21S2G6
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 16
Letzte 30 Tage: 79
Insgesamt: 1,464
